Old 10-12-2019, 05:44 PM   #1
1320NUT
1320NUT's Avatar
Tire & Wheel size
what would some or most of you recommend for a tire/wheel size for a 1990 454ss with a 2/4 lowering kit? Thanks
1320NUT is offline   Reply With Quote
Old 10-13-2019, 02:29 PM   #2
SCOTI
SCOTI's Avatar
Re: Tire & Wheel size
What 'look' do you favor? Old school 15" combo, 'plus-one' sizing (16-18"), or big wheels 20-22's)??
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-13-2019, 02:45 PM   #3
1320NUT
1320NUT's Avatar
Looking at these would like an 18". http://us-mags.com/desperado-5-u423-w-7472.htm
Old 10-14-2019, 10:50 AM   #4
SCOTI
SCOTI's Avatar
Do you rotate/expect to rotate the tires or do you normally run different front/rear sizing?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-14-2019, 11:32 AM   #5
1320NUT
1320NUT's Avatar
Yes I plan on Rotating them same size all around
Old 10-14-2019, 03:45 PM   #6
SCOTI
SCOTI's Avatar
OE rubber was 275/60-15 on 7" wide SS spec wheels if I recall correctly (or 28" tall).
255/50-18 = 28.03" so that's going to be your height limitation. Fronts will offer less clearance vs. rear so I would look into how much room you have w/an original set-up to help decide.
Some 255/50's on 8" wheels should be a good fit. If there's not enough clearance @ the fender opening, you'll need to go down in sidewall ratio ('45' series vs. '50' series) to get a shorter overall diameter. Backspacing (or offset depending on wheel manufacturer) will also play into what fits & works. It needs to be optimized if @ all possible.
I would do some internet searching for other 454ss trucks & get info on a set-up that is similar to what you visually like & go from there.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-24-2019, 08:50 AM   #7
Kudzupatch
Kudzupatch's Avatar
Take a few basic measurements and use this calculator. VERY HANDY!
You can try different combinations and see if the clear.
https://www.wheel-size.com/calc
Kudzupatch is offline   Reply With Quote
Old 10-24-2019, 04:33 PM   #8
1320NUT
1320NUT's Avatar
Thanks for the chart
