Old 10-06-2018, 06:08 PM   #1
Nightrider
Nightrider's Avatar
rear bumper help
Hey everyone. I have a 1984 c20 and I have the old big heavy rear bumper and I was wanting to get a new chrome smoothy for the back... But I still want to have my tow-hitch for pulling my trailers. So will I need new brackets and new tow package?
Thank you for your help!
] : - 71' burb,5.3,4wd
02' f350.7.3
00' F250-powerstroke
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Nightrider is offline   Reply With Quote
Old 10-08-2018, 11:22 AM   #2
SCOTI
SCOTI's Avatar
Re: rear bumper help
What's the current set-up? Bumper mounted ball or under the truck mounted hitch/receiver set-up?
Going to a smooth chrome 'sport' style bumper will require the under truck mounted hitch/receiver style set-up.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 10-08-2018, 04:26 PM   #3
Nightrider
Nightrider's Avatar
It has the hitch/receiver. So therefor I will have no problem with getting the smooth right?
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 10-08-2018, 04:57 PM   #4
SCOTI
SCOTI's Avatar
Most standard aftermarket hitches mount under the frame. The receiver tube + ball mount are usually located completely under the plate opening on the bumper.
You can research a hitch set-up for a Suburban, Blazer, or C10/20/30 w/the optional 'Sport' bumper. This could possibly provide measurements that you can compare to what's currently under the truck. Once you know/compare those numbers, as long as the ball mount is under the plate, the Sport bumper should swap w/o issue.
I have a 'hidden-hitch' set-up under my CC Square-body dually. It keeps the receiver tube tighter/closer to the frame which puts the ball mount positioned directly behind the license plate. I prefer the hitch tucked & out of site when not being used. I simply flip the plate up out of the way when I need to install the ball mount to tow the trailer.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-08-2018, 05:25 PM   #5
Nightrider
Nightrider's Avatar
ok thank you ill do some looking around.. Here are a few pics of mine.
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 10-09-2018, 09:35 AM   #6
SCOTI
SCOTI's Avatar
That shouldn't be an issue.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-09-2018, 11:06 AM   #7
Nightrider
Nightrider's Avatar
awesome thank you!
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 10-09-2018, 03:26 PM   #8
BigDooley77
BigDooley77's Avatar
x2
BigDooley77 is offline   Reply With Quote
Old 10-09-2018, 03:36 PM   #9
sweetk30
sweetk30's Avatar
thats a factory style or even o.e.m unit on the back .
you are looking for a sport rear bumper style like blazer & suburban all used and some trucks .
there the same bumper but specific brackets for each frame style .
i got mine off a 2wd c-10 suburban and only needed inner middle brackets . the outer ones were the same . bolted right up to my c-10 pickup .
made my own hidden hitch to hide all of it up in behind the flip down plate setup .
77-k30lb BIG truck build .
79-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
sweetk30 is offline   Reply With Quote
Old 10-11-2018, 01:21 AM   #10
LT7A
Truck looks good sweetk30.
Copyright ©2000 - 2018, vBulletin Solutions Inc.
