Old 10-08-2018, 06:09 AM   #1
LeesTruk
upper control arm nuts
Went to a show yesterday, and a fellow was looking in the engine bay. He turned to me and said "your alignment shims are laying under the control arms!" Sure enough, the control arm nuts had loosened, allowing the shims to slide out. After getting home and repairing the situation, I checked the search, and found this has happened to others, too. How common a problem is this, or should I have used new pinch nuts after I replaced the control arms?
LeesTruk is offline   Reply With Quote
Old 10-10-2018, 06:52 PM   #2
MikeB
MikeB's Avatar
Re: upper control arm nuts
Yes, definitely use locking nuts! The ones you need are called "prevailing torque lock nuts". I was able to find them at a local industrial supply store, but you can also get them at BoltDepot.com.
https://www.boltdepot.com/Flange_nut...in_finish.aspx
Mike
82 C10 Custom Deluxe SWB -- original paint, 355/TH350, Vortec heads, GM RamJet 350 roller cam
69 C10 LWB -- Bought in 1989, now my son's http://67-72chevytrucks.com/vboard/s...d.php?t=775449
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 18 years! This is the very first car or truck forum I joined.
MikeB is offline   Reply With Quote
Old 10-11-2018, 04:00 AM   #3
LeesTruk
Thanks for the info. Getting the truck re-aligned tomorrow
Copyright ©2000 - 2018, vBulletin Solutions Inc.
