Old 10-10-2018, 09:54 AM   #1
Andler2008
1984 C30 CC/LB "Daily Dually"
So I bought this 1984 C30 just over a month ago for $900. The 454 was long gone due to a thrown rod and it had some rockers left as well as a size 12 hole in the Driver side floor pan. The SM465 was still in there too, so that was a plus.
Backstory: I had been looking for an older chevy crew cab dually for about 3 years prior to this one and I always missed out on the good deals, or they were just priced well above what I had available, until now. I only happened to be able to get this one because I had been saving cash for a Magnum T56 for my 2003 mustang ls swap. Well, as you can see, I have a dually and no T56 lol
So far, I bought the LS Flywheel, SM465 clutch, LS7 pilot bearing and all of the associated ARP hardware to get it all bolted together. I installed the motor last night and bolted it down to the SM and used Dirty Dingo conversion mounts to use the OEM truck frame mounts.
I'll be installing the PS pump, alternator, intake and manifolds in the next day or two. I ordered 2 rockers from each side, both rear cab corners and the driver side floor pan last night. Once those arrive and my new spot weld cutters come in, I'll be getting the old ones removed and putting the new ones on.
Andler2008 is offline   Reply With Quote
Old 10-10-2018, 10:10 AM   #2
Andler2008
Re: 1984 C30 CC/LB "Daily Dually"
Also, here's some info on the motor, wiring and stuff that I did prior to purchasing the dually.
I parted out a 2001 Suburban to get the motor and wiring. I ultimately made money on parting it out, and was able to keep the engine and wiring, so I definitely came out way ahead.
Engine Prep
-LS9 7 layer headgaskets installed
-ARP head studs installed
Electronics/Wiring
-Modified OEM suburban wiring to be stand alone, using info from LT1tech.com
-Leash Electronics Big Dog II fuse block for the stand alone and additional accessories
-Purchased the HP Tuners Pro Suite and a new laptop. Built a bench harness to eliminate VATS and change a few things before hooking it up to the truck.
Fuel System
-Already bought tons of fittings and 20' of Braided -8AN hose from Vibrant Performance
-Using a Walbro 400 LPH pump, this may change depending on if I use the saddle tanks or go for a single 30 gallon from an older suburban.
-Using the OEM FPR from the suburban on the OEM intake
As far as my plans for the truck, I plan on bagging the front and rear. I have no plans on laying body at the moment, but it's not 100% out of the question. I just want to get the truck running and driving, then fix up the body and remove the rust before doing the big suspension stuff.
Things seem to be moving a lot quicker than I initially anticipated, so I'm getting very excited as more things get completed.
Old 10-10-2018, 11:50 AM   #3
Warrens69GMC
Warrens69GMC's Avatar
Welcome aboard and congrats with your new project!
To post pictures here i take them with my phone, which uploads to google. I then view them in google and save them to my computer.
When you want to post them, I click the "go advanced" button on the post, and click the paperclip in the top header. Select the photos you want to post, then press "upload", then "close this window" in the upper right corner , then you can hit "post reply"
1969 307, t350
1950 Chevy Wagon
Old 10-10-2018, 11:53 AM   #4
Andler2008
Yeah, I know how to get them on there, but it seems I do not have access yet. I assume I have a minimum post requirement before I can post pictures.
Old 10-10-2018, 11:57 AM   #5
Warrens69GMC
Your pics...
1969 307, t350
1950 Chevy Wagon
Old 10-10-2018, 11:58 AM   #6
Andler2008
Your pics...
It just let me upload them lol Thank you though
Old 10-11-2018, 11:07 AM   #7
Andler2008
I got 4 rocker panels (2 left and 2 right) and both cab corners in last night. Looks like the floor pan and the spotweld cutters will be here today.
I will be ordering an EFI 31 or 40 gallon suburban tank with the fuel pump assembly. I have a walbro 400 that I'll put in place of the OEM pump, so that will be an easy swap to get my 58psi at the rails.
I'll be super busy with my son's football scrimmage tonight and practice tomorrow with a game on Saturday morning. Then I'm taking the wife and kids to the Good Guys 1st Kentucky National after the game on Saturday. Hopefully I'll get some time in on the truck on Sunday as my wife has designated it as her "Sunday Bumday" this week lol.
1984 C30 Crew Cab/Long Bed Dually -- 5.3 LM7/SM465 Build Thread Here:http://67-72chevytrucks.com/vboard/s...d.php?t=772972
Old 10-11-2018, 12:27 PM   #8
BigDooley77
BigDooley77's Avatar
Smile Re: 1984 C30 CC/LB "Daily Dually"
Looking forward to updates. I'm also building a CCDW.
1977 GMC Sierra Classic CCDW. 454 worked 781s, 277/287, Lift .502/.501 LS 114, Dual plane intake, Dana 70 (4.10) and 4L80e (HD2 kit).
http://67-72chevytrucks.com/vboard/s...63#post8361863
BigDooley77 is offline   Reply With Quote
Old 10-11-2018, 01:32 PM   #9
Andler2008
lol I literally just commented on your thread. Looks like you've got a good truck to start with.
Old 10-11-2018, 05:25 PM   #10
BigDooley77
yeah its something to start with lol its got some rust but not much this summer I'll start tearing the body apart but before I start all that I want as much road time as possible.
Old 10-11-2018, 05:28 PM   #11
BigDooley77
Are you going to use a Pollak fuel selector and run 2 separate fuel pumps? or 1 saddle tank? or go suburban rear tank?
Old 10-12-2018, 09:13 AM   #12
Andler2008
lol I literally just ordered a 31 gallon fuel tank and fuel pickup from a 1988 R20 Suburban on rockauto.com. Total cost was just south of $200. I don't like the saddle tanks and switch. Between the location outside of the frame rails and the additional wiring and plumbing for the switch, I'd rather just use 1 tank in the rear between the rails.
I already have the 400lph fuel pump and the proper in tank fuel hose. Now that I've got that ordered, I may put the body work on hold until I can fab up some mounts for the new tank and get it plumbed and installed.
I have 20' of -8AN braided fuel hose, a whole bunch of hose ends, the adapters for the OEM LS truck rails, 10 micron fuel filter, etc. I made sure that the sending unit I got had the threaded o-ring ends that way I can just adapt some AN hose end fittings to it for ease of installation. Hopefully
Old 10-17-2018, 05:16 PM   #13
Andler2008
So I got my fuel tank and fuel pickup as well as the tools needed to help drill out the spot welds on the OEM body panels.
I handle staffing for a national logistics company and I'm working with our 2nd shift team to figure out why they cannot meet our Service Levels set in place. I typically work on 1st, but this week I'm on 2nd so it has really thrown me through a loop. Sleep isn't terribly different, but now that I can sleep in until noon, I have been taking advantage lol so no work is getting done until the weekend.
I did have my wife try and help me push the truck into my shop so I can get working on it, but the rear wheels were locked up for some reason so I assume the E-Brake is hanging up. I got it angled towards the front door, but not through as it's a tight space between the attached garage and my shop.
I am hoping to get my father in laws wrecker over to the house to help pivot the rear end and push it into the shop.
I plan on removing the bed as soon as I get time when the truck is in the shop and I'll start removing the saddle tanks and looking to install the new suburban tank. Can't wait to get working on this project.
Old 10-18-2018, 10:45 AM   #14
BigDooley77
HAHA yeah these things suck to move mine was right outside the shop door with 3 of us pushing and it wouldn't move so I just finished hooking up what I could had the kid manually select the gear under the truck and then drove it in. I like the saddle tanks but the rear tank is nice too you can hinge the tail light and have the fill neck behind it kind of like an old Cadillac.
Old 10-18-2018, 05:29 PM   #15
Andler2008
Yeah I have been considering doing the behind the tail light fill cap. So we shall see.
Copyright ©2000 - 2018, vBulletin Solutions Inc.
