11-17-2013, 03:03 PM | #1 |
Rear window install
Hello , I just scored a near perfect rear window for my big back window truck $10.00 at a swapmeet , Question, I have an after market rear sliding window in it now, But it has the factory rubber and chrome around the outer edge, My question is do I need to remove the outer rubber and factory chrome to get the new window in, THANKS
11-17-2013, 03:23 PM | #2 |
Re: Rear window install
i think so because when install back glass you need to put seal around glass before installing in the cab at least that is how i had to install mine. if you doother way you could break the glass
11-17-2013, 03:53 PM | #3 |
70+ ( Old Skool Club )
Yes you do. it has been noted that the chrome strip in the rubber cab be real difficult to install. I went from slider to flat glass with a new rubber snd chrome strip and took the truck to my local pro-glass shop to have it installed. I have found that sometimes its better to let a pro do certain jobs.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
11-17-2013, 04:08 PM | #4 |
I did a rear slider to solid glass install last week. I did the cord in the rubber trick and it was fairly easy. I ordered my new rubber from brothers. You can get standard or deluxe with the chrome for the same price. here is a how to link on the install.
11-17-2013, 08:27 PM | #5 |
Yes, you need to remove the gasket, trim and window all at the same time. Using a hook tool like in the picture below helps out a lot. A cotter pin extractor tool will work too, but not as good as these hook tools. Don't use any metal tools against the glass, they are for hooking the rubber over the pinchweld on the cab. In the video, it shows them using plastic sticks to pry the gasket over the pinchweld. This method will work, but not nearly as good as a hook tool. The plastic sticks are generally used for working the window into the gasket, hence no metal touching the edge of the glass. The back windows in these trucks are way easier to remove and install than the windshields are.
11-18-2013, 07:35 AM | #6 |
1969 Custom 30 wrecker
If your not re-using the gasket, just take a sharp utility knife and cut through it on the inside and pop the whole thing out. Then you can easily remove the trim and gasket from the slider frame.
Try installing the glass yourself! It's very easy to do even with trim. I had mine in within minutes.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
11-18-2013, 11:11 AM | #7 | |
11-18-2013, 04:18 PM | #8 |
Yes, installing a back glass using a piece of clothesline was too easy. A warmer day is better because it will make the gasket more pliable, especially if using an older gasket. And, it never hurts to have a little soapy water solution on hand just in case you run into a little bind.
1968 Custom SWB, 327/3 speed OTC 1969 CST LWB, 402/400 1970 CST LWB, 402/400 1970 Sierra Grande LWB, 350/350 1971 Cheyenne LWB, 350/350 1972 Cheyenne Super LWB, 402/400 1972 Sierra Grande LWB, 402/400 1979 Silverado LWB, 350/350 1984 Suburban 1990 454 SS 1991 Silverado, X-cab, 4.3/5 speed Getrag 2005 Silverado Crew Cab Corvettes: 75, 77, 78, 93, 96 |
