Old 12-04-2021, 05:45 PM   #1
lkt1954
Active Member
Rear Brake Line Help
I just got my rear cross over lines for my 69 C10 and I'm confused.
With the rear brake hoses on the calipers, the hard lines are way too long.
Are there different hoses and/or hard lines when you do a rear disc brake conversion?
lkt1954 is offline   Reply With Quote
Old 12-04-2021, 06:37 PM   #2
SCOTI
SCOTI's Avatar
Re: Rear Brake Line Help
Yes. The hard lines after the 'T' split are different on drum vs. disc brake equipped vehicles. You probably want to search for new rear 'disc brake' hardlines (or make your own).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-04-2021, 07:30 PM   #3
lkt1954
Active Member
What confuses me is I ordered these hard lines from inline tube and told them it was a rear disc brake conversion and yet I got the normal rear hard lines.
The right hoses almost would reach the tee.
Old 12-05-2021, 10:50 AM   #4
lkt1954
Active Member
One thought to help crossed my mind.
Currently the calipers are mounted with the hose down.
On the front calipers the bleed valve faces up- rear currently facing down.
Is this part of the issue?
Old 12-05-2021, 02:41 PM   #5
SCOTI
SCOTI's Avatar
Yes. Bleeders should be @ the top.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-06-2021, 09:59 AM   #6
lkt1954
Active Member
All bleeders are on top.
Does anyone make a rear disc brake conversion lines?
What about shorter brake hoses?
I prefer not to have to make my own lines.
Old 12-06-2021, 10:45 AM   #7
SCOTI
SCOTI's Avatar
I don't know of aftermarket disc brake rear hard lines being sold individually. I would guess they're part of a larger kit only but I've also never searched online specifically for them either. Whatever vehicle set-up the calipers & backing plates are sourced from would be where I started looking.
You would need to post up some more detailed images on what you're working with to determine if shorter hoses might help from an outsiders perspective.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-06-2021, 02:17 PM   #8
lkt1954
Active Member
Here are some more pictures with all lines laid in place.
The hard lines are run as if they were connecting to drum brakes.
The flex hose on the right is 3" short of the tee block and the left flex hose is about 24" short of the tee.
I see a few options:
1) Use braided flex hose in place of the hard lines.
2) Find pre made shorter lines and bend to fit.
3) Shorten the lines I currently have and hope I get good flares.
Any other thoughts??
Old 12-06-2021, 02:32 PM   #9
cwcarpenter98
cwcarpenter98's Avatar
I shortened a couple lines on my truck. It wasn't too hard to get a good flare, even with using the tools rented from your local parts store
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 12-06-2021, 02:49 PM   #10
SCOTI
SCOTI's Avatar
Easiest option I see is shortening the existing lines to terminate into a tab on the rear end housing @ each side (similar to how the fronts are terminated & done).
As far as flaring tubing, doing a flare on a straight length of mild steel brake/fuel tubing is fairly strait-forward.
If you don't want to go that route, ordering in flex lines the required length would be the next option.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-07-2021, 08:33 AM   #11
Joyridin
If it were me, I would ditch those 2 foot long hoses and get some short SS or even rubber hoses. Run your steel lines close to the wheel and put your 3 way block wherever is convenient. Having those rubber lines dangle all over the place looks like an accident waiting to happen.
Joyridin is offline   Reply With Quote
