Old 09-15-2009, 10:52 PM   #51
SCOTI
SCOTI's Avatar
Re: lowered shortbeds on stock wheels?
Working, lowered, & on Ralleys . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-16-2009, 12:10 AM   #52
joe231
joe231's Avatar
mine
a coil and 3 inches cut off the front springs, and the short, thick overload leaf and 2 other removed from the rear pack leaving 3 leafs
8 inch rallys with 235/75/15's
Name:  DSC00458 (Medium).jpg
it is under going some renovation at the moment
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 09-16-2009, 12:35 PM   #53
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
can you give us some more specs on you truck? drop and tire size??
"san diego chargers #1"
joe1982 is offline   Reply With Quote
Old 09-16-2009, 01:25 PM   #54
StepinNJ
TuTone Silverado
StepinNJ's Avatar
Originally Posted by silvereagle07 View Post
Looks great, I like the black rallyes. I'd like to see your summer wheels(avatar).
Here they are 20X8.5
13 Corvette GS vert
13 Ram Laramie Longhorn
11 Wrangler Sahara unlimited
08 300
76 El Camino
67 Bel Air sedan
63 Corvette SWC
08 HD Road King Classic
68 HD Golf car
StepinNJ is offline   Reply With Quote
Old 09-16-2009, 01:53 PM   #55
joe231
joe231's Avatar
StepinNJ, What is you drop and back-spacing?
CHEVY ONLY
Old 09-16-2009, 02:17 PM   #56
SCOTI
SCOTI's Avatar
3" Bell Tech spindles
1-coil cut off OE V8 springs
1-ton 1.25" sway bar on Energy Suspension bushings
Gabriel replacement gas shocks w/owner fabbed upper relocation bracket
215-70-15 BFG's on 15x6.5" van ralleys
shaved lower a-arm lip @ BJ area for wheel clearance
Western Chassis flip kit (HD 8-leaf spring option)
Bell Tech shackles
WC bolt-in c-sections (bolted-in w/GRADE-8 hardware + welded
WC shock extensions
Gabriel gas shocks for 73-87 GM 4x4 front
Owner fabbed air-over leaf set-up (manual fill w/schrader valves)
255-70-15 BFG's on 15x8" truck ralleys
Hidden CLASS IV Hitch
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-16-2009, 02:22 PM   #57
joe231
joe231's Avatar
Captain Thorough to the rescue!!!
excellent info
CHEVY ONLY
Old 09-16-2009, 06:31 PM   #58
fiddy9apache
fiddy9apache's Avatar
heres my old 85...
van ralleys on front and wide truck ralleys on the rear. i can remember the front tire size but the rear is a 275-60 drag radial.
fiddy9apache is offline   Reply With Quote
Old 09-16-2009, 07:00 PM   #59
JohnC
JohnC's Avatar
What was the setup on it?
JohnC is offline   Reply With Quote
Old 09-16-2009, 07:01 PM   #60
fiddy9apache
a 6/8 drop
Old 09-16-2009, 07:48 PM   #61
nlped
nlped's Avatar
Here is a shot of mine.
It has a 2.5" spindle on the front with a Belltech 1" coil that I actually cut a 1/2 a coil off of, for a total of about 4.5"in the front. The rear is just a flip bracket that I made due to the '96 rearend swap.
I replaced the shocks in the front with Belltech Nitro Drop shocks and replaced a few bushing and the upper balljoints at the same time I installed the drop. After doing all of that, it actually rides a heck of a lot better than it did in stock trim.
It has 15x8" rallies w/ 255/70r15's which calculate out to about 29" tall and they do NOT rub at all. I have future plans for 18" wheels but no bigger because I tow a ski boat with it, and don't want to ruin the ride.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-16-2009, 07:50 PM   #62
menace121978
menace121978's Avatar
^^ your truck sure looks sick buddy.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-16-2009, 08:05 PM   #63
nlped
nlped's Avatar
Thanks, It's still a work in progress though. Gotta have that 5.3L
Carter
Old 09-16-2009, 09:13 PM   #64
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
man nlped, i know that you are a victom of the boss 338,but dude, the truck is super clean man. i think this looks perfect with these wheels. do you know what over all drop you have? i just got my wheel vintique vette stlyed rally's. i just ordered 2 15x8's because the 15x10''s for the rear where out of stock. i think i might go 8''s all around after seeing your setup. do you have anymore pics?
Old 09-16-2009, 09:26 PM   #65
nlped
nlped's Avatar
The measurement's when I started vs. when I finally finished the drop at the fenders works out to 4.5" front and 5.5" rear. I'm not totally convinced that I want to notch the rear frame because the rearend only hits the frame if I hit a hell of a bump, and I am still using the ORIGINAL rear shocks without relocators. Those are next .
Carter
Old 09-17-2009, 08:33 AM   #66
JohnC
JohnC's Avatar
Nlped this is yet another fine example of a beautiful stock looking truck. That thing is beautiful! Got a few "right click save's" in that post.
Old 09-17-2009, 12:20 PM   #67
nlped
nlped's Avatar
Thanks a lot John, I appreciate it!
Carter
Old 09-17-2009, 03:51 PM   #68
dga93
newbie
dga93's Avatar
where is the cheapest place to buy the lowering kits? i was thinking of getting the 4/6.
Daniel from AUS
1978 CD
dga93 is offline   Reply With Quote
Old 09-17-2009, 05:26 PM   #69
flamingbig10
6.0 powered square
flamingbig10's Avatar
comes with a c-notch
western chassis $500 for 4-6 and 5-7
http://sporttruckdirect.com/C10_kits.html
mcgaughys 562
http://www.stylintrucks.com/parts.as...sults_trigger=
beltec $630
http://sporttruckdirect.com/Belltech_Drop_Specials.html
no c-notch
djm 5-5 $488
http://www.stylintrucks.com/part.asp...&partid=559744
parts from summit
3" summits coils $74(ground force)
http://www.summitracing.com/parts/SUM-G726/
djm flip kit $85
http://www.summitracing.com/parts/DJM-FK1024-5/
cp spindles $210
http://www.summitracing.com/parts/CLP-CP4S4/
total $369
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 09-18-2009, 09:09 AM   #70
Chlsnk
Chlsnk's Avatar
What is the drop you have on this?
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 09-18-2009, 09:10 AM   #71
SCOTI
SCOTI's Avatar
A little more than 5/7.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-18-2009, 09:20 AM   #72
Chlsnk
Chlsnk's Avatar
Thanks! looks Great!
Old 09-19-2009, 01:00 PM   #73
nlped
nlped's Avatar
I pieced my drop together off of Ebay and managed to get the MgGaughy 2.5" spindles (so I wouldn't run into any rubbing issues with the factory 15" wheels), the Belltech 1" drop springs (I ended up pulling them back out and cutting a 1/2 a coil off to get it to sit how I wanted it), Belltech Nitro front shocks, and I built the flip bracket myself for the rearend out of an $8 piece of material and $25 labor at a machine shop up the road. My grand total for all the above mentioned parts was approximately $350. Just an fyi
Carter
Old 09-20-2009, 01:10 AM   #74
CHEESE
The Cheesiest
CHEESE's Avatar
not the best pic for this topic but the red & white one is lowered on rallys
[IMG][/IMG]
CHEESE is offline   Reply With Quote
Old 09-20-2009, 01:45 AM   #75
texasfunk
texasfunk's Avatar
here is a better one of it
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
