08-26-2016, 09:46 PM | #1 |
Trailer hitch receiver for '72 with step bumper
I hope this helps save someone else the trouble I had getting a trailer hitch to fit my '72 C20 with a step bumper. I bought online and got every important measurement right except one, so I had to return it and order a different one. Don't just trust the website that says it fits!
These are the important measurements to consider when getting a trailer hitch for a truck with a step bumper. You will probably have to call the manufacturer to get these, as they are usually not available with the online specs. A - Make sure that the hitch will fit between the bumper brackets B - Make sure that the bolt holes will line up on the center of the truck frame C - Make sure the hitch drops far enough to fit beneath the bumper D - Make sure the hitch sticks far enough out beyond the bumper Other tips: - Look closely at the online pictures of the receiver you are considering to make sure the design works with your bumper. - Consider the realistic towing capacity of these old trucks. Class IV is probably good enough. - Shop around. I found a wide variety of prices online for the same part number. Amazon and eTrailer are good places to start. |
01-16-2017, 02:36 PM | #2 |
Knuckle Buster, Instructor
Re: Trailer hitch receiver for '72 with step bumper
That is a nice fitting hitch. What part number did you end up with? Was it listed for your application? I've considered hitting the salvage yard with measurements in hand to see what might come close. My C30 needs a hitch. The 71 and Blazer already had them.
Current classic fleet: 72 K5 Blazer CST, unrestored factory Orange paint...mostly 69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration 53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue |
01-16-2017, 04:04 PM | #3 |
It's a Draw-Tite 41001. It is listed to work for my truck with a stock bumper, but not for a step bumper. Probably because some step bumpers drop down more. I didn't want one that hangs down 3-4 inches below the bumper, so it was definitely worth a phone call.
01-17-2017, 08:09 AM | #4 |
Nice hitch! I've been looking around and trying to figure mine out with having Boyd rear tank.
01-17-2017, 09:34 AM | #5 |
That's a really nice hitch. Any idea if it would interfere with the under bed spare? Do you happen to have the pertinent dimensions you indicated from this hitch? I have a very similar step bumper.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
01-17-2017, 12:05 PM | #6 | |
I couldn't remember the dimensions, but it was easy to measure. It drops 5.5" and sticks out about 10.5" past the end of the frame. |
05-01-2017, 11:59 AM | #7 |
Nice hitch, I have the same rear bumper on my 72 C20. Amazon has that hitch for $119. going to order today. Thanks for the pics of your truck. I will be towing a 20' Trailmanor, that weighs 2800 lbs dry, i figure 3300 max loaded, shouldn't be a problem.
correction, amazon is weird sometimes,,came up initially at $119 but when clicked to cart, popped up at $143. I still think its a good value for my needs. Last edited by nevada; 05-01-2017 at 03:33 PM. |
04-15-2019, 11:55 PM | #8 |
Guest
Posts: n/a
Somewhat old thread but I have the same step bumper on my 72' K10 Cheyenne. Mine is from the original owner and when she picked picked up her truck it had a chrome bumper. She had the dealer take off the chrome bumper and put the same step bumper as shown above in the pictures. Truck is from the Freemont plant and sold to her by Marx Chevrolet in Gilroy, CA. It does not look like other dealer installed step bumpers from but it is the same as the ones pictured above and it was installed in 72' by the dealer.
04-16-2019, 07:23 AM | #9 |
SWB 4x4 Collector
I went with a class V hitch from B&W on mine. It fits under my 72’ v43 step bumper perfect.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
05-24-2020, 11:07 PM | #10 |
Jimbosprint,
Thanks for posting this detail. Question - did you ever get around to installing a spare tire with the original mounting hardware? Curious if the OE spare tire mount will clear this hitch. Thanks! |
05-25-2020, 02:05 PM | #11 |
Sorry, I never added a spare tire carrier.
Tags |
hitch, receiver, towing, trailer |
