10-13-2019, 08:53 PM | #1 |
Engine rebuild. Question on heads
So I got my motor. After tearing into it, I found out it had heads off of a 78’ 305. Not terrible but not great either. They need rebuilt as well so I figured I would look into a more desirable set of heads. Here is where my question comes in. From what I’ve read on this site and others is that getting headers that fit is kind of a bear. I guess the “rams horn” style is the way to go? So I was wondering since I’m getting different heads anyway should I be looking for ones with straight plugs or angled? I appreciate any and all advice. Here is a pick of the engine coming out and a pick of my finished front end it’s going into. Just because we all like those pictures
Thank you Posted via Mobile Device |
10-13-2019, 09:01 PM | #2 |
Re: Engine rebuild. Question on heads
Shameless plug, how about these? http://67-72chevytrucks.com/vboard/s...d.php?t=794278.
10-13-2019, 09:48 PM | #3 | |
10-14-2019, 12:56 AM | #4 |
Factory angle plug heads only came over the parts counter and never on a production vehicle as far as I know. Truthfully unless you run domed pistons with 11.5 or higher compression ratio they are a waste anyhow as they are designed to work with domed pistons and not have a flame travel groove in the piston dome.
Now days you should be able to buy a set of decent cast iron heads from Summit or Jegs with valves and springs installed for what a set of "good" used heads and a fresh valve job costs. Either way you need to study up on it a bit and find heads that will do what you need them to but not be more than you need with a performance stage that your engine doesn't need. I kind of had my buddy's valve grinder sold out from under me yesterday when I was too late asking about it. I had done a number of heads with it over the past 25 years.
10-14-2019, 10:02 AM | #5 |
Hears a list of casting numbers and what they are. Might help confusion or add to it.
http://outintheshop.com/faq/casting/heads.html |
10-14-2019, 05:49 PM | #6 |
Yeah not confused on heads in general. My only real question is since I’m getting different ones, which ones make it easier for fitting headers?
I will probably be getting a set from summit unless I find a set of 041 or 186 with a price I can’t pass up. Posted via Mobile Device |
10-14-2019, 06:55 PM | #7 |
Are you sure that's not a 305 engine? Monte Carlo's were never equipped with a 5.7 after '77. The original 305 heads will have 58 cc chambers and 1.72/1.50 valves. Switching to a larger chamber will give up compression. There is additional concern of older 5.7 heads having the valve centers farther apart which, combined with 1.94" or 2.02" valves can cause conflict with cylinder block.
1980+ 305 heads generally have 1.84/1.50 valves for better flow. Because the valve centers are closer together you can use 1.94" valves with a mild cam. Or you can use a head with wider centers and pay to have the valve center moved. But you might not gain much. TPI aluminum L98 heads are 58cc and have 1.94/1.50 valves while the 305 version comes with 1.84" intake. Aluminum headfs can allow more advance without the detonation. My truck uses a set of cheapie headers that I removed from a '74 K1500 in the '90s. The actually fit well. I welded the flanges up then had them machined flat, and I cut the upper flange into three sections to allow for expansion. I have doughnuts at the bottom to allow engine flex. The headers have been installed since '96. I have 1985 305 heads using straight plugs on a 302 bottom end. Some of the plugs are a little tight and require me to install the spark plug socket on the plug then a wrench on the socket. No big deal. |
10-14-2019, 07:42 PM | #8 |
It’s not the original engine from that car. Looked up the casting number and confirmed it was a 350.
10-14-2019, 09:40 PM | #9 | |
Modern head designs for street vehicles don't require angled plugs to get best flow. Go with straight. Be warned that if you get a Vortec head the centerline of the exhaust ports is not in line with the centerline of the bolt holes. You may have to "walk" the holes closer to the top of the header. |
10-15-2019, 07:50 AM | #10 | |
I’ve read vortec is a better head but I believe I would also have to change my intake if I got those. I don’t want to do that. The one it has is fine. I’m not trying to squeeze every horse out of this thing anyway. But to get these heads redone is only about $175 away from a new set at summit so I figured I’d go that route And end up better off Thank you for the responses. I appreciate the input from ppl who have “been there done that” |
10-15-2019, 03:19 PM | #11 | |
10-15-2019, 08:55 PM | #12 | |
Thank you |
