Old 08-15-2017, 05:03 PM   #1
kennyhammond
Just bought a 2002 chevy 4x4
I have some questions...one it has a 2003 front end and some lights don't match all the way ( the cat eyes ) Two it has a small oil drop from under the motor looks like it might be rear main seal but not sure.. think it had some front end damage from a previous wreck but was fixed and drives great sloppy steering but figure a whole ball joint kit will fix it ... drives good was wanting a decent work truck picked it up for 3800 has 183k miles rebuilt transmission state 2 shift kit ....anything I should be looking at or need to check..it's a work truck toy
kennyhammond is offline   Reply With Quote
Old 08-21-2017, 11:08 PM   #2
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Just bought a 2002 chevy 4x4
What lights don't match exactly do you have any pictures of the lights that you're talking about? I would definitely be getting that front end checked out and fixing all the worn out parts not a fan of having crappy or sloppy steering truck or car at all. Sounds like you got a decent play truck for the price though.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 08-22-2017, 12:24 AM   #3
kennyhammond
Yeah it's a decent truck I will post pictures of the lights..I took the grill off and found some tabs are broke ...looks better now...have a interior light problem and the worn out steering I am going to buy a whole 13 piece kit to replace all joints and sway bar ends ...any other things I should be looking at?
Old 08-22-2017, 06:16 PM   #4
Flying Hamster
Flying Hamster's Avatar
Intermediate shaft on the steering. It runs between the box and the column and has a rectangular slip/fit section for accidents. They ALL wear out. Every 40-50k miles like clockwork.
2006 Sierra RCSB V6 5 Speed RWD.
Flying Hamster is offline   Reply With Quote
Old 08-25-2017, 05:16 PM   #5
kennyhammond
I will have to look at that it has a deep growling when going around curves.
Old 09-10-2017, 06:35 PM   #6
kennyhammond
Well the shaft and all looks good without the engine running I had my wife turn the steering wheel and see what was giving ... The shaft to the steering box all looked good but there was probably about 2 inches of movement in the top under the box the big but for the idler arm was what I was looking at and it only moved 1 cm
