02-10-2014, 10:52 PM | #11 | |
Re: 1972 K5 4x4 modified build
For the standard stuff I use a Miller 210 MIG welder and I try to use a DX200 water cooled TIG. I have a ESAB plasma cutter and a Delta Drill press, along with a 13x40 lathe and 20 ton press. A few angle grinders and drills, etc. For a bender I use the JD2 Model 3 bender with 270* dies from 3/4"-2" in size: https://www.jd2.com/p-32-model-3-bender.aspx I added a air/hydraulic ram to bend the big tube, but you can bend up to 1" easily by hand. I built my own, but you can get this unit: http://www.ebay.com/itm/SWAG-Tubing-...item3f2afa9fb8. I use these style of dimple dies. They allow you to use them anywhere in addition to a press: http://www.ebay.com/itm/SWAG-Off-Roa...item3f2dd228d1 I also have a 3" unit which is kinda spendy. SWAG (dimple die guy above) also has a bandsaw stand and plate that I copied and I use it daily. It uses a Milwaukie Port-a-band and makes it a table top bandsaw. http://www.ebay.com/itm/SWAG-V4-0-Po...item3f2bac5c3b These jewels are indispensable in my opinion: Greenlee DTAPKITM M3-M10 6-Piece Combination...And add the 5/16" and 3/8" drill taps. I use these to make new and clean out old threads. Buy extras of the ones you use most, and pre-drill with the right size bit before using. That's about it, really. If you want to know something specific, let me know. |
