03-10-2017, 04:14 PM | #1 |
504 Green spray can
Anybody tried this 504 green from paintscratch.com?
https://www.paintscratch.com/cgi-bin/order-form.cgi Posted via Mobile Device |
03-10-2017, 04:31 PM | #2 |
Re: 504 Green spray can
I've not used that particular company before, but one very similar to it from AutomotiveTouchup.com. This wasn't for 504, but in general I've found their formula mixes are hit or miss. One car I had was a near perfect match, the other wasn't even close. The other thing I didn't like was the paint was only available as a two stage which it hard to match in appearance to the original single stage paint. If you have a little time to be patient, I would recommend Tower Paint. I sent them the ashtray from my old Beetle and the paint code and within one week I had a perfectly matched color in a spray can. The best part, they can make it in a single stage lacquer! I was so pleased with the results, I won't get paint from anywhere else.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
03-11-2017, 10:28 AM | #3 |
The best method of getting an aerosol to match is to do what Hewittca did by getting a painted piece in front of a supplier that can tint to match.
The reason is that over the years your truck painted the same color as mine, will have a slightly different color all these years later because of the difference in the environment our trucks have been in. One might be left on the deserts of Idaho or Arizona while the other always stored inside. On an aside, the type of paint won't matter when it comes to color. Color is color is color. The different brands of paint combined with the different paint technologies make no difference when it comes to color match. The way a color is sprayed can (but not always) change the color from the same can of paint. Disclaimer: certain new tri coat pearls not withstanding.
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
