09-16-2019, 03:31 PM | #851 |
Re: What did you do to your truck today.The 3rd chapter
I was way off - the one I have has an 8" stick.. I'd like a little longer, however now that I have this..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
09-16-2019, 10:28 PM | #852 |
At the body shop.
4 months later.
Dmv got my plates done.
" That didnt make it any newer " " Dont antique the equipment " |
09-22-2019, 04:24 PM | #853 |
Painted my filler panels. Oil change and rear axle fluid change.
09-22-2019, 04:43 PM | #854 |
Stain applied to the glove box and ash tray veneer - sanding and finish next
09-23-2019, 07:31 AM | #855 |
Finished bolting down the bed. Hung the tailgate. Wired the back-up and taillights. Installed the rear bumper and license plate lamp. Drove it for the first time.
09-25-2019, 01:42 AM | #856 |
New flywheel / pilot bearing / clutch / pressure plate / throw out bearing using ARP hardware. Next get the linkage assembled and drop the Muncie Rock crusher in
1967 short fleet with a 71 350 4 bolt using 67 bell housing / M-22 / Custom shaft / 3.73 posi Old school One more bite off the elephant .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 09-25-2019 at 01:57 AM. |
09-25-2019, 07:22 PM | #857 |
Patched the drivers side cab corner. Glad I didn't need to use the whole piece. It was about an inch to long had the same issue with the passenger side also.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 09-28-2019 at 08:42 AM. Reason: Spelling |
09-26-2019, 09:51 AM | #858 |
Aftermarket patch panels are horrible. There is obviously no Quality Control when it comes to them. Guess there are no c10's in China for test fitting 😆 mine were bad as well.
09-27-2019, 10:09 PM | #859 |
Taking rear section apart for cleanup and paint. Found at least part of why turn signals were not working right. This is the way I like my issues, very obvious. Looks like I’ll replace from firewall back to tail lights when I put it back together.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
09-28-2019, 01:15 AM | #860 |
Congratulations on the first drive!
1951 GMC 250 Open Express Pickup 1968 Suburban C10 1971 C20 Olive “People are shocked when they find out I’m not a good electrician” Dad told me “Son, never strike a man in anger- unless you’re certain you can get away with it” |
09-28-2019, 06:04 AM | #861 |
laying low
Me too. I hate chasing electrical issues. Probably most sketchy fixes are done on the fly with the intention of getting back to it to do a proper repair and many just don't.
09-28-2019, 08:07 PM | #862 |
Who Changed This?
Came back from CostCo with groceries and discovered a bunch of pieces of plastic alongside my truck. I realized that it looked the strip that covers the screws that attach the top to the sides of the camper shell. Got out a ladder and looked on top, and sure enough, there was a bunch missing. How it managed to "explode" overnight out of the channel it sits in is beyond me. I'll check my security cameras, but this would be the most random kind of vandalism that could occur. I'm guessing that it started and then propagated. I walked by that side of the truck yesterday and would have seen it. Guess I'll be buying more of it. That shell is only 2-1/2 years old. I'll buy black this time, since black is more resistant to UV. Anyone know where to buy that stuff? Maybe I can call the installers for that info on Monday.
09-28-2019, 10:02 PM | #863 | |
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
09-28-2019, 10:36 PM | #864 |
Who Changed This?
Thanks for that info! I'll be replacing it all, and there's a lot of it. Since I'm going to use black, I'll probably change my truck's name to "Tiger" because of all that black trim on an orange truck. What with a white shell, I can pretend it's an old tiger with white hair on top. Heh, I amuse me.
09-29-2019, 08:06 AM | #865 |
Glad I'm getting down to just the detail stuff after my build. Finally found the right air filter, 5.5 inches tall. Undercoated the wheel wells. Painted the front suspension. Painted the front calipers Chevy orange for a splash of color 😁.
09-29-2019, 09:57 PM | #866 |
Got the hood on and a small shake-down drive. Next up: front alignment.
09-29-2019, 10:13 PM | #867 |
Picked up some pavers for a project in the backyard.
09-30-2019, 08:18 AM | #868 |
SR,
I think yours falls into the what did you do WITH your truck today! HA! I still like it though. Out there still doing truck things.
09-30-2019, 10:40 PM | #869 |
I got my front clip on and took it it for drive. Still need hood hinges, my old ones were shot and the ones that came with the clip are stuck open. And then I need body work and paint. Of coarse I've needed that for 22 years.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
10-02-2019, 09:49 AM | #870 |
Working on the finish now on this project - 4 coats in..
10-02-2019, 10:30 AM | #871 |
Ned,
What wood is that veneer? The glove box lid looks book matched. Nice.
10-02-2019, 10:43 AM | #872 |
Thank you. It is quarter sawn red oak - matching the wood in the bed in both stain and finish. Also the ashtray face, and a radio delete I made...
10-02-2019, 07:57 PM | #873 |
laying low
I think it will look better with that front end. It fits.
10-02-2019, 09:05 PM | #874 |
Yep, it just got real, real fun. Half a day of drilling out spotwelds and pulling sheet metal by myself. MIG gas cylinder (75/25) picked up, and just so happened my cab/radiator mounts came in too. I also ordered up the Brother’s radiator support patch. A little pricey, but that thing is really well made and stout. Tomorrow I’ll finish the cuts on the underside of the cowl/dash area and possibly start tacking in my patch pieces.
1971 Custom/10 - 350/3 speed, Orange/White roof |
10-02-2019, 10:40 PM | #875 |
Who Changed This?
I was thinking quarter-sawn white oak. Either way, that is one beautiful bunch of work. I'd like to do something like this to my truck, but it would disappear down the rabbit hole of not being used for the rest of my life while it got worked on. I'm getting old.
