05-14-2016, 04:50 PM | #1 |
Master Cylinder with Booster Kit
I have a stock on the outside 42. I have installed a sbc and 700r4 using brackets and kits used for 47-54. They fit perfectly. I installed a disc brake setup on to the stock axle and now I am looking for an inexpensive master cylinder kit with 7 inch booster. I can get a 47-54kit for about 220. not sure if it will fit. Anyone try it? or know of a kit in the price range I am looking for?
Thanks for any help
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344 1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494 R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438 1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250 |
05-27-2016, 09:33 PM | #2 |
Re: Master Cylinder with Booster Kit
How about just the pedal bracket? the 47-54 kit does not work, I have it now. The pedal assembly hit the column
07-20-2016, 07:26 PM | #3 |
I finished the install of the 47to54 kit in a 42. You can't use original holes that are in the frame and there is a cross member to remove but if you changing the trans to an auto you need to remove it anyway. I have pics on my build page.
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344 1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494 R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438 1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250 Last edited by docrock; 07-20-2016 at 07:27 PM. Reason: dixlexic |
