01-15-2019, 05:51 PM | #1 |
Post Whore
Fuel tank liner
Is there a best of the best tank liner?...I pulled my tank and flushed it out today it's got some rust inside (no suprise)...most of the ones I've read about only last a few yrs it seems...
01-16-2019, 12:09 PM | #2 |
Re: Fuel tank liner
Years ago I bought tank sealer from aviation supply house. Used a product they recommended to flush the tank and then sealer. Used a chunk of chain in tank with cleaner to knock any loose stuff off. Figured if it was good enough for aviation it would be just fine for my ‘55. Pulled tank years later to go with fuel injection tank and still looked great.
1955 Chevy, 2 dr post, my first car 1969 Chevy C20 Suburban, 6.0 LS w/4L80 2001 Silverado Z71, 5.3 extended cab |
01-16-2019, 12:30 PM | #3 |
Re: Fuel tank liner
I have sealed many tanks in the past, lots of motorcycle tanks. The last car tank I sealed was a few years back. I used Northern Radiator tank liner kit, worked well. One kit will do up to 20 gallons.
https://www.amazon.com/Northern-Radi...19513276&psc=1 |
01-16-2019, 02:21 PM | #4 |
Post Whore
Re: Fuel tank liner
Thanks ....I hadn't thought about aviation supply...I'll check into it
And what BW showed...
01-16-2019, 11:24 PM | #5 |
Post Whore
Re: Fuel tank liner
after doing some reading I think im going with the Bill Hirsch tank sealer kit....it comes with the wash, the etch, and the sealer..theyve been around since the 60s and have great reviews.....http://www.hirschauto.com/AUTOMOTIVE...ctinfo/ARK-01/
01-25-2019, 03:07 PM | #6 |
Re: Fuel tank liner
RedKote you can get it at Oreilly's. don't forget to flush the tank out first and get all the rust out. If you can get the tank acid dipped first and then coat it. We have a local place that will dip the tank and coat it for a little over 100$. but we have an acid bath here at work and i leave the tank in there over the weekend and take it home and coat it myself.
01-25-2019, 04:06 PM | #7 |
Post Whore
Re: Fuel tank liner
Yeah the Hirsch kit comes with acid etcher...
01-25-2019, 09:23 PM | #8 |
Re: Fuel tank liner
Isn't a new tank around $100? I'm pretty sure that's all I paid for one a couple years ago.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-25-2019, 09:30 PM | #9 |
Post Whore
Re: Fuel tank liner
Cadillac....they don't make tanks for this truck....its still very solid ...just has some internal rust
01-26-2019, 06:44 AM | #10 |
Re: Fuel tank liner
OK it must be the 55. I was thinking it was the 81. Good luck.
01-26-2019, 08:26 AM | #11 |
Post Whore
Re: Fuel tank liner
Your close...its the 57 IH
