Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 01-06-2018, 09:53 AM   #1
Bob252
1993 chevy Silverado 4.3l xcab c1500 low heat problem
My heater barely works but my temp is 195 the heater hoses seem to be at about the same temperature. No over heat problem present. Coolant level is good. But the heater just won't blow hot. This has been a problem for years but lately the temperature outside has hit record lows. Please help. 😩😩😩😩😩😩😩😩
Bob252 is offline   Reply With Quote
Old 01-06-2018, 11:25 AM   #2
b454rat
Re: 1993 chevy Silverado 4.3l xcab c1500 low heat problem
Heater core is prolly plugged. Pull lines off, blow air thru the return side of the core.
Old 01-06-2018, 01:11 PM   #3
Bob252
Angry Re: 1993 chevy Silverado 4.3l xcab c1500 low heat problem
Did that. No change. Still only luke warm air coming out.
What mechanisms makes the cold air hot?
If there is a door that controls this. Where is it on a 1993 chevy truck?
Old 01-06-2018, 04:24 PM   #4
b454rat
There is a door in there that controls air flow. Not sure how it works or where it is. Guess I've been lucky with the pre-95s that the heat works lol.
Old 01-06-2018, 07:07 PM   #5
mountie
mountie's Avatar
There is a door to allow heat to enter cab. located, sort of below / right side of radio. access by removing glove box..... to left of glove box opening....
Also ...maybe your heater core is covered with leaves & junk. The stuff that wiggles it's way down from the vent, at bottom of windshield.
( When I replaced my A/C, I found my heater core covered with crap )
( My '88 Sierra )
'70 GTO Midnight Blue
'88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany.
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
'05 GMC Yukon XL , SLT 4wd ( just purchased 2018)
mountie is offline   Reply With Quote
Old 01-06-2018, 10:04 PM   #6
ninety6
not really a lot to getting heat --- suggestions above will hopefully get you going. Its going to be either not enough hot coolant getting to/through the heater core (bad t-stat or clogged core or line), or the air going through the vents isn't going across the heater core due to a blend door issue, or as suggested, maybe even leaves!
ninety6 is offline   Reply With Quote
Old 01-15-2018, 11:35 PM   #7
diveplane
called actuator flap controls all 3 modes in vent, sometimes the mechanism sticks ,some wd40 does the trick.
like someone mentioned heater core could be plugged up, or a hose but that in return would over heat your truck as well.
diveplane is offline   Reply With Quote
Old 01-15-2018, 11:40 PM   #8
diveplane
my 94 this flap unit is drivers side under dash.
Copyright ©2000 - 2018, vBulletin Solutions Inc.
