Old 10-20-2015, 07:29 PM   #1
87bbcs10
1950 6100 floor push starter
Ok I just picked up a1950 6100. I'm am going to build it into a wrecker truck. I wanna run a small block Chevy or big block not set on witch, but the truck has the floor starter setup. I would like to know if anyone has ever used that setup on a small block Chevy style starter? Any information will help thanks greatly appreciate it
87bbcs10 is offline   Reply With Quote
Old 10-20-2015, 08:29 PM   #2
OrrieG
OrrieG's Avatar
Re: 1950 6100 floor push starter
Swap the on off switch for a starter switch cover up the hole in the floor. Only sixes came with the floor start.
OrrieG is offline   Reply With Quote
Old 10-20-2015, 08:32 PM   #3
87bbcs10
I want to keep the floor starter there has to be a way of can use it on a different starter. I can't believe no one hasn't tried to use it or has information on trying it.
Old 10-20-2015, 09:57 PM   #4
OrrieG
OrrieG's Avatar
Two issues I can see. First is there enough room above the starter for the manual solenoid? Second the V8 is wider, so starter is farther to the passenger side, which means the bracket and arm will need extended. You will need to mock it up and start fabricating.
Old 10-20-2015, 10:46 PM   #5
torchlight
torchlight's Avatar
The original starter pedal used a mechanical linkage to mechanically activate the starter on trucks with the old straight six engines. That linkage is set up for the location of the starter on those engines and won't work with a modern v8 engine. You can absolutely still keep a starter pedal though. You'd just need to use an electrical switch rather than a mechanical linkage. Using something like a floor mounted momentary starter switch allows you to keep a stock starter pedal appearance and function and work with a different engine. These switches can be easily found in tractor parts catalogs. That's what I did in my truck:
Build Thread: "Marvin" (1953 3100)
torchlight is offline   Reply With Quote
Thread Tools
Display Modes
