Old 12-07-2018, 11:18 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Help. Which way does the slant go???
After removing and cleaning the cross member in my Sons 69 I noticed that the center of it is slightly angled. Problem is I didn’t watch whicway it came out, I thought you could install it either way HELP
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 12-08-2018, 12:41 AM   #2
1970 CST Short Wide
Senior Moment
Re: Help. Which way does the slant go???
Nobody?.. come on gurus, somebody has to know
Pittsburg Ca
94565
Old 12-08-2018, 01:30 AM   #3
68bowtie
68bowtie's Avatar
What cross member?
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Project "Blue Bomb" (70 c30 blue original paint refresh)
Project "Vitamin C" (71 c10 orange original paint refresh)
Old 12-08-2018, 01:35 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Lot of stuff going on on a Friday night. The weekends are usually a little slow anyway. There are six cross members in a coil spring truck, so a little more info would be nice.
LockDoc
Leon
Old 12-08-2018, 01:50 AM   #5
kwmech
Assuming an auto trans mount x-member, the slant goes towards the rear
Old 12-08-2018, 02:40 AM   #6
Roc
Bet it's the one second from the back...where you put the gas tank swap...it's angled
Roc is offline   Reply With Quote
Old 12-08-2018, 02:41 AM   #7
Roc
I can measure and shoot pics by lunch tomorrow of mine
Old 12-08-2018, 09:31 AM   #8
LockDoc
LockDoc's Avatar
The very front one is angled too, the small one in front of the main front x-member.
LockDoc
Leon
Old 12-08-2018, 10:22 AM   #9
Grumpy old man
Grumpy old man's Avatar
Here's a pic of the front x member.
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 12-08-2018, 01:58 PM   #10
1970 CST Short Wide
Senior Moment
My Bad. Trans Cross member
Pittsburg Ca
94565
Old 12-08-2018, 01:59 PM   #11
1970 CST Short Wide
Senior Moment
That’s what I needed to know
Thank you very much
Steve
Pittsburg Ca
94565
Old 12-09-2018, 08:07 AM   #12
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
You lost me at angle. The rear wall of the cross member has holes in it for the E-brake cable brackets.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-09-2018, 10:02 PM   #13
1970 CST Short Wide
Senior Moment
On our Trans X member were you show the arrows it’s slanted / angled down for one side to the other
Pittsburg Ca
94565
Old 12-10-2018, 08:24 PM   #14
71CHEVYSHORTBED402
Those corners incline toward the front inside. But like I say, the rear of the cross member has two holes for the E-brake cable brackets.
Tony
Old 12-10-2018, 10:31 PM   #15
1970 CST Short Wide
Senior Moment
Thank you, that helps a lot
Steve
Pittsburg Ca
94565
Thread Tools
Display Modes
