Old 09-02-2017, 10:38 AM   #1
rayce88
250 engine stands to mount 5.3
Can I use my original 250 6 cylinder stands in my 67 to mount my 5.3 ? ..... I had planned on using 73 up mounts and dirty dingos but already have the 250 mounts.... has any one done this ?
rayce88 is offline   Reply With Quote
Old 09-02-2017, 12:28 PM   #2
68Stepbed
68Stepbed's Avatar
Re: 250 engine stands to mount 5.3
Yes, I actually like to recommend this as it gives better weight distribution.
Most don't listen to me, though.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 09-02-2017, 01:17 PM   #3
rayce88
I was looking at trans- dap 4204 ..... and put the perches in the v8 holes ? ..... but I think I will have to lose the low mount AC
Old 09-04-2017, 03:01 PM   #4
68Stepbed
68Stepbed's Avatar
Don't use anything from Trans-Dapt!!! Go ahead and spend the few extra bucks and get the Dirty Dingo mounts. Ask me how I know to give this advice.
Also, I like to recommend THESE engine stands. Yes, the factory perches will work, but these new tubular stands are stronger and accept the more common urethane motor mounts. However, DO NOT get the rubber engine mounts!!!!! THEY WILL BREAK!!!!! I can show you pictures of what happens to them after about a year of driving.
Matt
Old 09-04-2017, 03:35 PM   #5
Willie Makeit
Willie Makeit's Avatar
yup. my supercharged 5.3 is sitting on I6 towers with dirty dingo sliders & stock rubber motor mounts.
been that way for several years now with no issues.
Willie Makeit is offline   Reply With Quote
Old 09-04-2017, 04:39 PM   #6
68Stepbed
68Stepbed's Avatar
Let me rephrase. The stock style mounts aren't as bad. I'm referring to the cheap Chinese mounts made to work with the tubular perches above. The metal is weak and starts coming breaking apart.
Matt
Old 09-05-2017, 12:15 PM   #7
scoot_mcgrute
I used the 250 engine stands with my 5.3 swap in my 66 and it worked out great! The motor seems a little lower than most and is definitely farther back which is what I was shooting for. I had to move the engine to the "2 inches forward" location on the adapters to fit the firewall and I love it.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 06-05-2018, 10:14 PM   #8
67pete300
My head is swimming trying to sort through all the motor mount threads and info. And it appears there is great proliferation of options so I'm confused.
I am replacing a 250/3spd in a 65 C10 with a 4.8/4L60 with electric fans.
Dirty Dingo adapter plates seem to be a good option but there are several types and nobody specifies which "Dirty Dingos" they are using. here are two options I see:
https://www.amazon.com/Dirty-Dingo-C...s+motor+mounts
https://www.amazon.com/Dirty-Dingo-S...s+motor+mounts
I'd like to keep the I6 towers if possible but don't know what combination of mounts to connect the adapter plates to the towers.
I'd like to keep the option of the stock low mount AC compressor. Open to new towers if that is what is required.
I'd like to reuse the stock driveshaft if at all possible.
Another option is to go with this CPP kit:
http://www.classicperform.com/NewPro.../6372ELS-K.htm
Can anyone help me with more specific recommendations?
67pete300 is offline   Reply With Quote
Old 06-07-2018, 03:59 PM   #9
68Stepbed
68Stepbed's Avatar
Use the sliders. https://www.amazon.com/Dirty-Dingo-S...s+motor+mounts
As for the perches, you can use the stock I6 perches, and Energy Suspension makes poly mounts. https://www.performanceonline.com/19...or-Mount-Pair/
I also used an ECE trans crossmember. With the sliders, you can align the trans crossmember with existing bolt holes. https://www.earlyclassic.com/node/1055
Matt
Old 06-09-2018, 11:13 AM   #10
67pete300
This is great! Thanks.
If I get the POL mounts I'll take a look at their crossmember to see if I can save some shipping.
https://www.performanceonline.com/19...n-Crossmember/
Does anyone have experience with using the DD Sliders and the stock low mount AC?
Next step, manifolds.....
Old 06-11-2018, 09:08 PM   #11
67pete300
Looking hard at this kit:
http://www.classicperform.com/NewPro...NSTALL-KIT.htm
Would love some feedback if anyone has experience with it. I think there is a better chance of using the stock low AC bracket and having the manifolds clear the perches.
