10-21-2018, 08:41 PM | #1 |
vac. advance canister ?
My recent tune up found vacuum canister was not working . Is a stock 350 4 barrel 9-1 comp ,very very mild cam . Old can says AV 20 but was wondering if I would benefit with a adjustable vacuum advance with such bad gas these days or just go to the #20 canister . I did read that the buick AR 12 was a good canister to use on a HEI 350. Not a race truck just a daily driver . Is in a 80 truck
10-22-2018, 06:56 AM | #2 |
Re: vac. advance canister ?
I would put in the one it calls for and see how it runs. You can go with the adjustable if you have a good dial back timing light to track the changes. While you have it apart check to see if the springs and weights under the rotor look in good shape. I have seen may a one that were flat worn out and not working like they should.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-22-2018, 12:24 PM | #3 |
A lot of the adjustable units only adjust how much advance you get, not when it comes in. And some of them come in pretty fast once you hit the magic vacuum. Almost a binary on/off switch.
Not sure how many of the OEM #s are still available. Might want to check when your mechanical starts to come in and when it is all in. You may want to adjust while you have the dizzy open. |
10-24-2018, 08:46 PM | #4 |
Thanks , just trying to get my head wrapped around tuning . I just thought 15 BTDC + 20 vacuum was alot . More reading needs to be done.
10-24-2018, 09:36 PM | #5 |
I wonder if it came with a 20 or if it got replaced at some time. It does sound like a lot for a truck.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
10-26-2018, 06:07 PM | #6 |
Fabricate till you "puke"
Blazer, each engine combo "tunes" a little differently That said, I ran a 9 to 1 , 355.....214/224 on cam duration. If you run low gears, or a loose converter(mine had 4.10 gears)....they tend to tolerate more advance, as they are not lugging the engine? That old 355, liked around a 32-34 total (initial + mechanical advance). But she liked another 12-14 on the vacumn advance(crankshaft, & hooked to a full vac port). You will need to tune & play, to find the right spot.....what I tell, is general info on the SB chev. best of luck...tuning is 1 step at a time. Have fun, any ?, ask! Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
10-27-2018, 09:18 AM | #7 |
I know is an art form and trial and error not like installing a water pump where is pretty straight forward. Doing lots of reading and u tube stuff. Just hate the dist. at the back. MY ribs hurt LOL
10-27-2018, 10:22 AM | #8 |
If I have 12 HG of vac. at idle would it be safe to assume that a AS-20 vac. can. wouldn,t even be working ?
10-27-2018, 10:34 AM | #9 |
No!
IIRC the stamped number on the pot arm is the number of degrees of timing it adds. You should get a mityvac pump and test the vac pot for how much timing it adds with how much vacuum you apply to it. |
10-27-2018, 12:09 PM | #10 | |
There used to be a book at the parts stores that told how much advance each can had and what vacuum it came in. There were literally hundreds of different combinations. Computerized engine management sure killed that business.
10-27-2018, 12:33 PM | #11 |
Maybe he should just buy or build a limiter like in this link.
http://www.crankshaftcoalition.com/w...EI_distributor |
10-27-2018, 04:00 PM | #12 |
Thanks caddilac ,There is a good write up called tuning 101 I believe and it lists all the cannisters.
Geezer my 12 HG vacuum is with the dist disconnected , don,t know if that means anything as the old cannister has failed and is disconnected now. |
10-27-2018, 04:52 PM | #13 |
What makes you think the vac pot is dead?
Did you draw a vacuum on it? And if so, how? |
10-27-2018, 08:51 PM | #14 |
10-27-2018, 09:14 PM | #15 |
That don’t prove anything.
Put a long vac hose on it and use your lungs to pull a vacuum on it. If the idle increases it’s good. |
10-27-2018, 09:55 PM | #16 |
10-27-2018, 11:43 PM | #17 |
60-66 Nut
If your vacuum advance is connected to ported vacuum, it isn't going to change the idle at all. Now if you connect it to manifold vacuum, then it will advance the timing and increase the idle.
10-28-2018, 08:49 AM | #18 |
It,s on Manifold vacuum
10-28-2018, 04:01 PM | #19 |
Short horn here... (thats for you geezer)! I totally agree, but will ask....what is the initial timing/total, & what is the duration on the camshaft? Also when is the mechanical curve "all in"? longhorn
11-07-2018, 11:47 AM | #20 |
Mr. Short Horn!
Good to see you’re still kickin’! Anywho I found some info on vac cans I figured I’d post. https://www.crankshaftcoalition.com/...ance_Specs.pdf |
11-07-2018, 01:30 PM | #21 |
I have mine set up similarly. 350, 9.5:1, 184/194 cam. 14-15 base + 20 mechanical = 34-35 all in, and ~12-14 vacuum. When I had more vacuum advance, it would ping while the choke was on. When the choke is on, the engine runs richer, so the air fuel mixture in the cylinder burns faster.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
11-09-2018, 07:24 PM | #22 | |
11-10-2018, 09:54 PM | #23 |
Ha d to fix the Jeep for winter. Anyway got a chance to do all this reading but was wondering what they mean by tip in. Is this the first # on the the specs. Ex. AR-12 starts 7-9 - 7@10-12. AR-15 3-5 -7.5@9-11.
11-10-2018, 10:50 PM | #24 |
Exactly where do they mention tip in.
11-11-2018, 09:59 AM | #25 |
Too much info in my head, has to do with a limiter plate but isn,t what I wanted to know. Are the first #,s HG starts at 7-9 . Is this when the vacuum starts to work at idle. If so why do some start at 7-9 and others at 3-5 . Is this due to the camshaft profile on different motors ?
