Old 05-24-2019, 02:14 PM   #1
shultzee13
2005 Chevy Suburban Coolant Issue
I have a new to me 2005 chevy suburban LT 5.3L
I cant seem to keep dex cool in the reservoir. The top radiator hose is not hard. It is hot but not hard, easy to squeeze.
I do not see any visible leaks anywhere. I filled with dex cool last night and drove 30 miles to work and now coolant gone again.
I do not see any leaks or puddles anywhere. AC is ice cold.
Temp gauge runs straight up n down 12 o clock. It's never ran hot. The low coolant light has never came on.
I cannot speak for what the previous owner has done but I have owned it for 3 months now and runs great!
I guess I am noticing this issue now because it's getting hot outside in Texas.
Thanks guys for any suggestions.
shultzee13 is offline   Reply With Quote
Old 05-24-2019, 02:55 PM   #2
Re: 2005 Chevy Suburban Coolant Issue
Check the oil and see if it is getting into there. Intake gaskets are know to leak on GM V8 and V6s after a bit of time.
Old 05-24-2019, 03:35 PM   #3
shultzee13
Nothing in the oil. All good there.
Just no pressure in top hose.
Old 05-24-2019, 03:38 PM   #4
shultzee13
Could a reservoir cap cause this? One where the oring has hardened?
Old 05-24-2019, 07:33 PM   #5
406flyfish
The intake gasket doesn’t have coolant going thru it. You need to fill it up and pressure test it to find the leak. The most common leaks are the water pump and the plastic heater nipple fittings.
Good luck
406flyfish is offline   Reply With Quote
Old 05-24-2019, 08:32 PM   #6
hatzie
Moderator
hatzie's Avatar
The 01-06 Suburbans with Castech cylinder heads lost coolant through cracks in the oil return wells.
TSB 06-06-01-019B
http://ww2.justanswer.com/uploads/Bl...t_loss_5.3.pdf
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
