Old 11-10-2019, 06:24 PM   #1
howell57
Chevy radiator fans draw
I have looked long and hard, but can not find the DC draw of dual OEM Chevy truck fans. I'm putting an OEM (2019) radiator fan assembly into my 72 C10 and need a fan relay system. I think AC Delco makes them for GM. Going through autocoolguy.com and they need the numbers??
howell57 is offline   Reply With Quote
Old 11-11-2019, 01:46 PM   #2
DJStucker
Re: Chevy radiator fans draw
Hard to say without a part number. Aftermarket fan data is much more available than OEM. I’d assume if they are dual fans they will be somewhere between 30 and 50 amps. Don’t use a relay though, use a variable speed controller(s). They a MUCH easier on your charging system, and last longer than a relay. I have dual Spal fans and they pull 23 amps each so I have 2 variable speed controllers.
DJStucker is offline   Reply With Quote
Old 11-11-2019, 01:55 PM   #3
HO455
HO455's Avatar
Have you tried looking up what the fan fuse rating is?
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F3 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
HO455 is online now   Reply With Quote
Old 11-11-2019, 02:27 PM   #4
howell57
I know they are PMW fans and I have a part # for ACDelco 13592144 which is the OEM part. I will wait till I get the fan assembly and see if there are any numbers on it or have my son use a multimeter and hook them up to a battery and see what the startup draw is and full on draw.
TKX
Old 11-11-2019, 05:50 PM   #5
morepwr
Active Member
Make sure your alternator is rated for high enough amps. I have burned out an alternator before learning this little bit of info.
morepwr is offline   Reply With Quote
Old 11-11-2019, 07:20 PM   #6
howell57
Using all OEM items. Engine is a 2018 L83 and I'm sure the alternator is a 150 amp unit.
Old 11-12-2019, 11:27 AM   #7
MDPotter
MDPotter's Avatar
Not to hijack your thread, but I'm interested to see how you install a 2019 radiator/fan assembly into your 72. I've looked at doing a similar install but with a 2006 radiator but they're too long to fit in the core support from my research.
1968 GMC C15 - Gen III 6.0 Restomod in progress http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - upcoming build
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
2016 Sierra 1500 All Terrain SLT - 33's, leveling kit, muffler delete
MDPotter is offline   Reply With Quote
Old 11-12-2019, 12:01 PM   #8
howell57
No problem! My thought is to mount the 40" radiator to the two vertical supports facing the engine. Center to center is just about 40". I have 6" from the face of those supports to the water pump pulley. The radiator and fan assembly is 4", should have 2" clearance. I have moved the battery and will move the horns. In order to maximize air flow, I could cut the core support to open it up to the two front vertical imprints on the core. I will be getting the assembly Wednesday, put the two units together and see how they fit.
Old 11-12-2019, 12:40 PM   #9
Wrenchbender Ret
I can't imagine running those fans without relay/s. With all the controllers & switches that the current goes through, it would put an extreme load on them, besides voltage loss through all the circuits.
George
Wrenchbender Ret is offline   Reply With Quote
Old 11-12-2019, 12:47 PM   #10
Andy4639
Orignal Goof member
Andy4639's Avatar
Thumbs up Re: Chevy radiator fans draw
Always run fans with relays! Always. If you want the variable speed hook it up to trigger the relay.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-12-2019, 01:17 PM   #11
howell57
ACDelco part # 13592144 is the OEM relay for this fan assembly. Chevy dealer says that there is only one relay to run both PWM fans. I've tried very hard to set it up as it came from factory. There is a 5 volt green trigger wire that turns the fans on from the ECU. System is set for variable speed fans.
Old 11-18-2019, 02:16 PM   #12
howell57
Did some metal work on support core and temporarily installed it. It fits snug with about 1&1/2" clearance. Fan support was thicker than I thought. This fan assembly has Bosch motors and that is unusual in that I thought they would be AC Delco, but it did come out of an 2019 Chevy Silverado???
Old 11-18-2019, 07:25 PM   #13
MDPotter
MDPotter's Avatar
Pictures?
Old 11-18-2019, 08:25 PM   #14
howell57
Old 11-18-2019, 08:46 PM   #15
howell57
Had my son post pictures as I would have never been able to do it!
Old 11-19-2019, 06:13 AM   #16
Andy4639
Orignal Goof member
Andy4639's Avatar
I resized your pictures, so we can see them better.
I think it looks good.
I'm not going to use the radiator but have been wondering if the AC condenser would work in a 67/72 truck? This pretty much say's it should. I think when I add the AC to my daughters truck I'll piece it together and use a late model condenser and stuff.
Old 11-19-2019, 03:17 PM   #17
howell57
Thanks for the resizing. My son uploaded the pictures remotely from his computer and may not have realized that they were seen that big.
Been trying to get information from GM and Bosch on the OEM fan assembly and no one will give me the time of day! Now I find out that GM is suing Bosch over their fuel injectors on the Duramx engines. Just looking for two pieces of information, amp draw of the Bosch fan motors and purpose of small third wire to the motor.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
