01-14-2020, 03:11 AM | #26 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Driveline angle question.
The front shaft should be inline or close to inline with the transmission. All three yokes should be phased inline with one another. If the slip joint was disassembled and reassembled one or more splines out of phase a vibration can occur. Lowering the truck decreases the angles reducing the u-joint stress. I'd suspect an imbalanced shaft and/or a yoke phasing problem.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
01-16-2020, 02:14 PM | #27 |
01-16-2020, 02:18 PM | #28 | |
01-16-2020, 02:54 PM | #29 |
Post Whore
You need a little angle in the ujoint to make the needles rotate in the cup to lubricate them...0 deg is not ideal..
Copied this... U-Joint Angles - U-joints need a slight angle for proper lubrication. Without the correct angles, the needle bearings in the u-joint caps do not rotate. Those needle bearings need to rotate in order for the u-joint to operate reliably and smoothly. These u-joint angles should always be at least 1-degree to avoid wearing out the yoke bearings. U-joints fail at 30* degrees.
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 01-16-2020 at 03:01 PM. |
02-02-2020, 10:07 PM | #30 |
A very generous forum member gave me a factory AT crossmember. I used it to support the 700R4 after I cut down the rubber tail shaft support mount.
For all that helped me through this effort, you deserve a few pics. All angles have horizontal as the reference. We have not driven the truck yet, but I’m pretty happy with how things measured once it was bolted down.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
02-02-2020, 11:27 PM | #31 |
Post Whore
on the pic with the differential in it ...did you mean to show angle down on the diff?...or is it up angle?
is this like your pics?
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 02-02-2020 at 11:37 PM. |
07-14-2020, 10:52 AM | #32 |
Thanks for this info. I am building a "66 from ground up with summits frame support and tranny mount, and just need to get the angle all correct.
