08-09-2003, 01:51 PM | #1 |
My other Love
Blew up the big block
well 11.5/1 compression and crappy quality premium petro canada fuel don't mix. When I tore the motor apart the piston in the #8 cylinder had a chunk taken out of it and at leats 2 piston rings are shattered, but luckily no other damage. In the past 8 years I have had that motor apart 7 times. Always stupid things like blown head gasket, broken con rod, bent push rod stuff like that. Just the romance of an old pickup I guess
MEMBER DISCS UP FRONT CLUB
Hooter_5@hotmail.com AC/DC RULES!!! First generation Monte Carlo club pictures of my life |
08-09-2003, 02:32 PM | #2 |
Sorry to hear that Hooter. Is the bore smooth? Gas sure sucks these days. I've had good luck with homemade octane booster. The store brands are too expensive.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint ______________________________ |
08-09-2003, 02:47 PM | #3 |
I have had the same problems in the past. A friend of mine turned me on to an additive of tetraethyl lead. It relly has helped as far as performance and pre-detonation. you can check it out at batterystuff.com. As far as I am concerned the only way to effectively raise octane and treat my valves right is with lead.
08-09-2003, 03:32 PM | #4 |
Yikes, don't get caught!
08-09-2003, 03:44 PM | #5 |
My other Love
what's the recipie for homemade octane booster?
08-09-2003, 06:32 PM | #6 |
PROJECT 7DEUCE
Homemade huh ????
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-09-2003, 11:14 PM | #7 |
Check out these octane boosters.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
08-10-2003, 03:23 AM | #8 |
neonlarrys got it there! Stuff like that. The same chemicals at Home Depot are used in the store brands, except at 300% less cost. Except I use Marvel Mystery Oil for a lubricant. Its great for the valves as well.
