10-17-2018, 03:12 PM | #1 |
mini truck racer
Fuel pump question
I am doing a 2001 Suburban drive train 5.3/4L60E/ 10 bolt 8.6 narrowed into a 1977 chevy Luv . I am having an aluminum fuel tank built to bolt into the factory location . I bought an aluminum fuel pump ring to have added to the top of the cell . May question is can the factory fuel pump be shortened to work with the new fuel cell ? I am installing all the drive train components as is and stock .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
10-17-2018, 03:22 PM | #2 |
Re: Fuel pump question
Although not factory, i think holley make an adjustable depth fuel pump...what fuel pump ring do you have?
10-17-2018, 05:30 PM | #3 |
They're spring loaded and will collapse to a given height, but when it stops, if you cut things and go further, you'll start linking the lines. Truck senders are pretty tall, but Tahoe ones are much shorter, may look into one of them.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
10-18-2018, 06:10 AM | #4 |
mini truck racer
I'm not sure. It is a factory 2001 suburban. I didnt know there were different rings .
10-18-2018, 06:12 AM | #5 |
mini truck racer
I was trying to keep everything but the harness as stock as possible. This is my first swap and will be leading up to a high end LS swap on my 49
10-18-2018, 10:25 PM | #6 |
mini truck racer
99-06 small ring
