Old 10-05-2007, 08:06 PM   #1
lotussutol
what 4 link is the best bang for your buck?
It seems there are tons of companies that make 4 links and the prices are from 100ish bucks to 1k.
I know that the cheapest is not always the crapiest and the most expensive is not always the best...but I also know a lot of times you get what you pay for.
so, with that said what are some good 4links out there at a decent price for 55 to 59 chevy trucks?
on the cheap price end I see there is the FBI stuff. they have heim and bushing end kits for around 200 bucks. And with that said what is better? heim or bushing?
on the expensive side there is the mark williams kit for 800ish dollars.
in between is the heidt Rear 4-Link, Plain $369
so...which have you used and or like?
Also, what is available for the 55-59 chevy trucks instead of the universal kits?
Lotus
Current Rides/Projects
1955.5 Chevy shortbed truck
1952 Chevy Coupe Deluxe car
lotussutol is offline   Reply With Quote
Old 10-05-2007, 10:33 PM   #2
highlow
Re: what 4 link is the best bang for your buck?
I don't know enough about all of the different ones, but on a triangulated 4 link, the air ride brand is pretty well built and decent price,
I would stay away from chassis tech aim industries that whole group whatever they call themselves in all the different mags. I have one of thiers, and really cheaply built, yeah it would work but very cheap! Thats my 2 cents
highlow is offline   Reply With Quote
Old 10-05-2007, 10:52 PM   #3
Kid
Kid's Avatar
I used the Air Ride Tech triangulated 4 bars. Good quality parts, but the mig welds could look better. If I had it to do over, I would buy the parts sep.. & do the welding myself. I do like the triangulated 4 bar best because it is the simplest, with no pan hard bar, therefore keeps the rear centered throughout the travel arc.
Kid is offline   Reply With Quote
Old 10-06-2007, 12:32 AM   #4
poncho_villa
poncho_villa's Avatar
If you haven't already, check out this link;
http://www.67-72chevytrucks.com/vboa...d.php?t=242546
Might be some interesting reference material there to help you decide.
poncho_villa is offline   Reply With Quote
Old 10-06-2007, 02:17 AM   #5
lotussutol
I am thinking about these two...
249.95
This kit includes
(4) Extra long 4 Link bars to allow for trimming With 2.5" Tube end welded to one side
(4) 3/4-16 Weld in Bungs
(4) 2.5" 3/4-16 RH Rod ends
(8) 2.5" Bushing Sets
(4) 1/4" Lower Axle Brackets
(4) 1/4" Upper Axle Brackets
(4) 1/4" Short Mounting Tabs
(4) 1/4" Long Mounting Tabs
(1) Grade 8 harware pack
279.95
High Quality Universal Triangulated 4-Link Kit with extra long 4-link tubes to allow you to cut them down to your preferred length. Polyurethane bushings and zerk fittings keep things properly lubed and squeak free. Threaded studs and 4-link tubes are TIG welded for maximum strength. All mounting tabs are CNC laser cut from 1/4" plate. CNC machined threaded bungs fit perfectly into the 4-link tubes. Zinc plated, Grade 8 mounting hardware included.
[IMG]http://www.*****************/images/products/UniversalTriangulated4-LinkKit.jpg[/IMG]
Lotus
Old 10-06-2007, 08:15 AM   #6
Bills_49
Broke Club =(
you could also look at www.***************** they have some good kits there. i have also been searching for one this week.
Bills_49 is offline   Reply With Quote
Old 10-06-2007, 09:35 AM   #7
robin58
Another vote for Jason at suicidedoors. Tell him what you're doing and he'll work with you.
robin58 is offline   Reply With Quote
Old 10-06-2007, 11:42 AM   #8
Kabwe
Certified Car Nut
Kabwe's Avatar
I have the Heidts and I like it I think it is nicely built.
Kabwe is offline   Reply With Quote
Old 10-06-2007, 12:54 PM   #9
lotussutol
on the two kits that I have been looking at the second one is from suicide doors.
Lotus
Old 10-06-2007, 01:26 PM   #10
entourageguy
Yellow truck club
entourageguy's Avatar
I picked up an ART ARS14550 parrallel with air bags for $450 off ebay. It's for an 88-98 full size and the bars are about 6" longer than the kits for the 55-59. I think with the longer bars the ride is a bit better as well.
Brian ...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 10-06-2007, 03:11 PM   #11
dwcsr
Hollister Road Co.
dwcsr's Avatar
There is a difference in 4 bar and 4 link. 4 bar is the ART and FBI kit. A 4 link is the Mark williams style kit which is geared more toward drag racing. 4 Links give you a lot of adjustability for better take offs to plant the tires. 4 Bars are what you should be using on the street less setup head aches and a better ride due to the longer bars. On a 4 link you could get your self into trouble on corners if not setup correctly. You could end up with a bad push or the rear coming around when braking when it normally wouldn't with a 4 bar. If this is your first or second suspension install I would stay with a 4 bar that has very little adjustability. The ART type kit has the ride already engineered into it.
Old 10-06-2007, 03:28 PM   #12
lotussutol
this even though it says 4link is really a 4 bar setup...right?
I am pretty sure this is the one I am going with.
It is 279 from suicide brothers...
I am also looking for a rear air bag kit...suicide doors has a ton of them ranging from 219 to 249. Can anybody look at this page and tell me what one they think would work best. It is all greek to me on air bags.
http://*****************/RearAirbagKi...racketKits.php
thanks a ton.
Lotus
Old 10-06-2007, 03:37 PM   #13
hotrodsbyray
anybody ever use No Limit Engineering kits - their ads make their kits sound good but i have no experience ordering from them.
hotrodsbyray is offline   Reply With Quote
Old 10-06-2007, 08:45 PM   #14
solidaxel
solidaxel's Avatar
No Limit is very beefey with there larger bars, Very good products and middle of the road for prices, when you order from Rob ask him when you can expect to receive them!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-06-2007, 08:57 PM   #15
dwcsr
Hollister Road Co.
dwcsr's Avatar
What rear end are you using? GM 12 bolt is harder to install one on. A Ford 9 is easier. The difference being that the ford is is a heavy sheet metal Pumpkin housing and the GM is cast so you will have to weld on the tubes for the GM and can weld on the Housing on the ford.
Old 10-08-2007, 11:11 AM   #16
1-ton of fun
polishing a turd
1-ton of fun's Avatar
i don't like the inherent design flaws in a triangulated 4 link, but many guys like them. i think people are overly concerned with the arcing travel of a panhard bar. in reality, with a decent length bar, the side to side travel is not much at all.
4-bars and 4-links, they are basically the same, but what is referred to as a 4-bar, the links are parallel with each other, and a 4-link the bars converge to create an instant center that can be used to tune launch characteristics
i am going to use individual parts from suicide doors to build a custom converging offset 3-link.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 11-03-2007, 02:58 AM   #17
dastuck
dastuck's Avatar
Ive been looking for a triangulated 4-link also. I have been tempted with going with the FBI kit as well. I didnt like the fact that they didnt have weld in bungs due to the fact that i would like to cut my tubes to my own desired length. The only suggestion I can give that you might consider is getting a kit that has Left hand and right hand joints. A lot of kits only run right hand threads. Having left hand on one end and right hand on the other end of your tubes allows you to make adjustments on your suspension while its still bolted under the truck.
dastuck is offline   Reply With Quote
Old 11-03-2007, 10:12 AM   #18
low-n-fat
i always like ***************** they have the nicest 4 links
low-n-fat is offline   Reply With Quote
