Old 03-15-2018, 09:47 AM   #1
dave`12
dave`12's Avatar
Hissing brakes help please
Not sure where to put this. My daughters 2002 S10:
when you push the brakes light (but enough to stop truck) all is normal.
brakes hiss when you push medium hard. the hissing noise is in the cabin, the plunger going into the power booster. Brakes still work, and feel like power brakes.
Never experienced this. Could it just be that something suppressing the noise has deteriorated?
Hoping that I don't have to replace the brake booster. It's quite tight there. If I do, could someone point me to instructions? I only see 2 bolts on the booster to the master cylinder, nothing else holding all this together. Not sure if removing them will allow me to pull the master cylinder away and pull out the booster?
Any advice appreciated!
Dave
dave`12 is offline   Reply With Quote
Old 03-15-2018, 10:16 AM   #2
b454rat
Re: Hissing brakes help please
Sounds like booster....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 03-15-2018, 10:22 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Yep. Booster seal may be leaking. Usually heard inside the cabin.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 03-15-2018, 10:47 AM   #4
truckdude239
truckdude239's Avatar
Needs a new brake booster
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-15-2018, 12:48 PM   #5
dave`12
dave`12's Avatar
Well, i figured as much, now it's unanimous.
Time to stretch before bending myself into a pretzel to get it out.
thanx
Old 03-15-2018, 01:57 PM   #6
61K10
61K10's Avatar
I have had 2 new boosters on my 61 tk both new. first on a 9" made noise in cab when pedal was applied. Second one is a duel diafram and it makes the same swish noise. no rubber or plastic boot inside at the firewall. Brakes work great just have that little noise.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-15-2018, 02:45 PM   #7
95 S_Trucker
95 S_Trucker's Avatar
There is a pin hole in the diapram. Unbolt the master cylinder. You can leave the brake lines hooked up. Make sure there isn't a brake fluid leak at the rear of the master cylinder. Thats the biggest cause of failed boosters. Then there are 4 nuts holding the booster to the firewall. The clip that holds the booster to the pedal rod is kinda a pita. Id have a new one handy. I usually break them upon removal.
95 S_Trucker is offline   Reply With Quote
Old 04-17-2018, 04:32 PM   #8
dave`12
dave`12's Avatar
that was it. fixed it. they made it about as tough as possible to get to the bolts.
thanx all
