Old 10-11-2018, 05:56 PM   #1
72 k15
72 k15's Avatar
New cab floor.
What company makes the best cab floors i've decided to fix my very rusty original cab. Truck came with rockers and a cab corner.
72 k15 is offline   Reply With Quote
Old 10-11-2018, 06:37 PM   #2
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Re: New cab floor.
I need to know this myself! Hopefully someone can help us.
FRANKENTRUCK
1981 Chevrolet C10 Deluxe Shortbed Stepside
GRANDTRUCK
1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
NEW PROJECT
1967 GMC 3500 dually one-ton flatbed
http://67-72chevytrucks.com/vboard/s...d.php?t=770578
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 10-11-2018, 07:53 PM   #3
AussieinNC
AussieinNC's Avatar
Re: New cab floor.
The last three cab floors I have replaced were either Triplus 400-4067 from AMD (Auto Metal Direct)
or # 849220 from Tommy's Pickup Parts here in Shelby NC
These things weigh in at 121 pounds...
Other brands seem to come in around 112 for other manufacturers like LMC etc..
I put the difference down to gauge of the metal itself.
Cant stress this enough...
Build yourself a set of cross brace bars to rigidly brace the cab before you remove the original floor...think 8 way bars, across both door openings, cross braced, then front braced to firewall in three locations, and rear brace to back wall of cab in two locations.
Cab stripped bare, cab off chassis and on dolly, cross braced, then on rotisserie, pivoting on cross brace points on door openings.
I cut the entire old floor out leaving 3/4" of old floor in place, then drill out the factory welds by hand...lots of cold chisel work and panel beating flanges etc.
Note: Most replacement floors are designed for column shift, low hump style vehicles....suggest if you need a high hump floor...do not cut new floor before its fully welded in place !
I have seen projects done without bracing....usually ends up with door openings wildly out of spec....
Good luck, hope this helps...
Family and country before all others...
1968 C-10 SWB
1974 C-10 Longbed
2001 GMC Sierra
2006 Chevy Silverado (Daily Driver)
AussieinNC is offline   Reply With Quote
Old 10-11-2018, 07:59 PM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: New cab floor.
Woodall makes some good products. Their bed floor is a very nice reproduction.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber...Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one.....Gen 5 5.3/6L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 Suburban was 3/4 ton, now 1/2....Wife shook her head...
71 C30 Wrecker....Cooter never had it this good...Wife actually smiled...
71meangreenc10 is offline   Reply With Quote
Old 10-11-2018, 08:11 PM   #5
72 k15
72 k15's Avatar
Re: New cab floor.
Suppose i should add i need a high hump floor to.
Old 10-11-2018, 11:04 PM   #6
kxmotox247
kxmotox247's Avatar
Re: New cab floor.
I used a Woodall High Hump cab floor and got it from SoKY Classics in Bowling Green Kentucky. It's a pretty decent piece. There were a few issues with the toe boards closing the gap completely and the kick panels fitting the contour of the floor But overall it seems decent.
Baby Blue's Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=652776
Project 68's Build Thread:
http://67-72chevytrucks.com/vboard/s...17#post8442117
kxmotox247 is offline   Reply With Quote
Old 10-11-2018, 11:07 PM   #7
kxmotox247
kxmotox247's Avatar
Re: New cab floor.
Sorry about the sideways photos. I used odd pieces of scrap metal from work for bracing. The rear floor to cab mounts in 67/68 were spot welded to the back of the cab and make it easier to install the floor. Also having a high hump helps to center the front. I had to cut the floor for my transmission tunnel as well. Hanging the cab and dropping it out from the bottom worked well for me.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
