Old 10-11-2018, 08:41 PM   #1
samkost
samkost's Avatar
Inner Door Panel Foam Donuts
Darn it!
I have been pretty good about bagging and tagging...Oh well.
On my 72 C10,
I can't find the four foam donuts for the inside door actuators and window cranks.
What have you guys done?
Make some up or a WTB thread?
Suggestions appreciated.
Stock photo for reference:
samkost is offline   Reply With Quote
Old 10-11-2018, 11:09 PM   #2
LockDoc
The Original Thread Killer
LockDoc's Avatar
Re: Inner Door Panel Foam Donuts
Originally Posted by samkost View Post
Darn it!
On my 72 C10,
I haven't had to make any of them and I don't know if the 1/2" foam water pipe insulation is big enough around or not, but maybe a guy could use a couple of different sizes to end up with the correct overall size....
LockDoc
Leon
Old 10-11-2018, 11:21 PM   #3
samkost
samkost's Avatar
I guess I will have to innovate.
Some round diameter foam and my hole punches should work.
Can't find replacements on any vendors web sites.
I assume the factory installed them for anti-rattle purposes? Not sure.
Thanks again Leon.
Old 10-11-2018, 11:24 PM   #4
ahlsy
ahlsy's Avatar
LMC used to carry them for the squarebodies...might be the same size...or close enough.
1972 K20 Suburban 350/350/205
2006 2500HD CCSB LBZ
1952 Willys Wagon
Members I have met: sicamous
ahlsy is offline   Reply With Quote
Old 10-11-2018, 11:34 PM   #5
samkost
samkost's Avatar
Excellent idea!
I will definitely check that out.
Thanks for the heads up Ahlsy
Old 10-12-2018, 06:59 AM   #6
GMCPaul
The 1947-66 trucks used the foam donuts behind the door panels, all the documentation we've seen which is the 1967-72 factory assembly manual and GM Truck master parts catalog show they were not used in 1967-72. We've seem them installed in some 67-72's and have always assumed previous owners added the 47-66 interior door handle foam seals.
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 10-12-2018, 03:55 PM   #7
402Bowtie
Paul Jr @ GMCPauls
Fwiw I've seen the donuts on some 72 doors that I'm certain were original.
402Bowtie is offline   Reply With Quote
Old 10-12-2018, 05:00 PM   #8
dfwright
dfwright's Avatar
I had the donuts on my truck, and I know they were from the factory
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 10-12-2018, 05:05 PM   #9
richard2717
richard2717's Avatar
PM your address & I will send you 4 originals if you still need them
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis
https://paypal.me/6772GMtruckparts .... Please click on goods and services and not friends & family otherwise your address will not show
5 OUT OF 6 PEOPLE AGREE THAT RUSSIAN ROULETTE IS SAFE!
richard2717 is offline   Reply With Quote
Old 10-12-2018, 06:49 PM   #10
samkost
samkost's Avatar
Richard, you made my day!
I finally realized where those door handle donuts went along with several other of my original and reusable C10 parts....MIA and long gone...
This takes a little of the sting out of getting my 72' away from of the restoration shop from Hell and back home to finish.
Slow but sure and a lesson learned.
Guys like you is why this site is the best.
Much appreciation and thanks again Richard
Sam
Old 10-13-2018, 07:19 AM   #11
darrellyates
Most of the parts suppliers for these trucks have them. I got some from Southern Kentucky. The upholstery guy said to just punch holes in regular foam... So a little block of foam with holes punched in it would work just as well.
Wound up not needing it on mine after I went to all the trouble to buy them.
I'd send them to you if I could find them....
darrellyates is offline   Reply With Quote
Old 10-13-2018, 07:24 AM   #12
72LB
72LB's Avatar
LockDoc
Foam water pipe insulation is what I used on two of mine. Cut to size and your good to go.
1969 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 10-13-2018, 07:26 AM   #13
richard2717
Sam
They will go out this morning's mail.
Glad to help
Thanks Richard
Members I have met.
Old 10-13-2018, 02:24 PM   #14
samkost
samkost's Avatar
Thanks again.
Copyright ©2000 - 2018, vBulletin Solutions Inc.
