Old 01-22-2021, 10:31 PM   #1
roushinator
roushinator's Avatar
72 C10 Chevy - LS with Entropy Radiator Lower Hose Solution
So I have been fighting this lower radiator hose on my truck project. 1972 C10 with LS3/Whipple with entropy radiator. People online with ďsimilarĒ builds were like ďoh go buy such and such hose and cut it and it will fitĒ. Well I did that (twice) and it never ďfitĒ right. I even tried to go the Autoplumb 16AN hose/fitting route. But it did not work out. So I thought about it for a while and realized the problem is the thermostat housing and that it mounts at the wrong angle and the outlet comes off at a weird angle too. Yeah that might work on the Camaro but not this truck. I needed a swivel 90 degree thermostat housing. But could not find one for my motor that was exactly what I wanted. They did have one for a Chevy 350. So I found an adapter and mounted the thermostat housing. The hose was now easy to make. Itís L shaped no weird bends. I still donít know if I am going to use those hose clamps though. I can see myself slashing my arms open later on.
Thermostat Housing Billet Specialties - BLK90220
Adapter Plate ICT Billet - 551491
HPS 1.5" 90 and straight
HPS 1.5" Billet 6061 Aluminum Joiner Hose Union Connector Black 2"
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 01-23-2021, 01:15 PM   #2
bigmoe
bigmoe's Avatar
Re: 72 C10 Chevy - LS with Entropy Radiator Lower Hose Solution
Always feels good when you come up with a solution to a problem. Can you not find a hose to fit now without splicing? I'm with you on the hose clamps. I wish someone made a better looking/functioning hose clamp.
bigmoe is offline   Reply With Quote
Old 01-23-2021, 06:42 PM   #3
LS short box
Great write up. Are those silicone hoses? If not I've great luck either making a one piece hose from a larger hose walking around the parts store stock room. Oreilly's typically has a good stock in the back room.
Or at NAPA they still have a hard copy parts book for hoses the give you basic dimensions for hoses. If you don't mod the hose you can send it back and get a new one.
Old 01-24-2021, 09:56 AM   #4
nsb29
nsb29's Avatar
Summit racing has a shrink clamp itís a band that you shrink with a heat gun. I had to cut mine and use a tube so I turned my clamps so the adjustment was to the back side and painted them black, but Iím going to order the shrink bands for the splice. the only complaint I saw was a guy used to large of band and it didnít get tight enough
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 01-24-2021, 02:27 PM   #5
roushinator
Well i thought the 90 that i ordered would be long enough but it was short by about 1.5" so i just spliced it
Ryan...
Old 01-24-2021, 02:28 PM   #6
roushinator
Yeah i am going to try those.
Ryan...
Old 01-24-2021, 04:48 PM   #7
A1971Blazer
A1971Blazer's Avatar
I didn't get a picture because I was just getting my radiator connected so I could start and run the engine
I had a bottom hose off a 2000 Tahoe 5.3 that I bought out of a wreck.
I trimmed out a section that fit pretty well on the Entropy for my LS1 swap
1967 C10 Stepside
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 01-24-2021, 06:32 PM   #8
LEEVON
Moderator
LEEVON's Avatar
Amazing tip! I never thought to adapt a small block outlet. I paid hell with the problem on my 5.3L 1950 pickup due to limited space and parts options, ended up fabbing one.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-24-2021, 09:08 PM   #9
nsb29
nsb29's Avatar
Call summit and make sure how itís sized if it goes hose size or outside diameter itís not clear at least not to me
Old 01-25-2021, 10:06 PM   #10
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I swapped a LM7 into my 70 K10. I guess I was one of the lucky ones who ended up being able to use a stock hose for my lower. My upper was another story. I ended up using two silicone 45-degree hoses with a piece of stainless tubing connecting them along with Gates shrink hose clamp. Worked out OK.
~ Dan
My Chevy Pics:https://app.sugarsync.com/iris/wf/D7...115878_6210284
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 02-01-2021, 10:41 AM   #11
Thealien
Thealien's Avatar
Tagging this for information, thanks.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
