12-28-2017, 07:06 PM | #1 |
BlahBlahBlah
Burb lift gate cables instead of brackets?
I feel like someone had replaced the lift gate brackets/arms with cables on their burb and did a thread about it, but I'm not finding a thing. Anyone?
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
06-03-2018, 12:37 PM | #2 |
low n' slo
Re: Burb lift gate cables instead of brackets?
im not sure where the link is but u can screw in the little ball studs that mount the gas pedal? been a while...but they screw in where the old lift arms go..then u mount a gas strut in its place. ill see if i can find it..
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
06-03-2018, 03:30 PM | #3 |
BlahBlahBlah
Ive seen those done for the barn doors and the hatch, but not the gate
06-03-2018, 03:37 PM | #4 |
low n' slo
06-03-2018, 03:40 PM | #5 |
I just installed a gas strut kit from Brothers on my lift gate. If it wasn't for one screw that wouldn't give up, the whole thing would have been done in 5 minutes. Very easy install, and they work awesome. Just unlatch the gate, and it rises up to the top on its own. No lifting,or bouncing the gate at the top to make sure both mechanical latches are engaged...
The kit was nice and saved some measuring, but it would be easy enough to take a few measurements and source the gas struts and ball pivots separately. |
06-03-2018, 07:04 PM | #6 |
BlahBlahBlah
I have the parts for what I call the hatch, the upper part with the glass in it. Got them using the posted link. Thanks for posting it up, excellent thread for those that missed it first time around.
I was looking for info on the drop down tail gate.
06-04-2018, 08:50 AM | #7 | |
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-04-2018, 10:18 PM | #8 |
BlahBlahBlah
Thanks Rob, I bet that was the one I saw.
06-04-2018, 11:21 PM | #9 |
low n' slo
ah yes totally missed that. i plan on doing the same exact thing..i threw those side hinges away a long time ago lol
06-05-2018, 08:29 AM | #10 |
I think the ones I used are off of a mid-90s truck, but they don't appear to be any different than the ones on my 2017 Silverado...
07-21-2018, 11:27 AM | #11 |
Coordinator of Synchronicity
Make sure you measure where you want your gate to sit
Before mine was torn down had a set off a newer chevy truck gate cables and they were a had short for my liking and you had to sometimes hop up to sit on the gate depending on where the rear bags were at
Rick 1971 Suburban ... W.I.P. Build Thread Customization is ones personal touch-- not what other people think it should be |
