Old 02-06-2018, 04:31 PM   #26
Turnip Truck
Turnip Truck's Avatar
Re: DIY4X crossmember fitment
Originally Posted by 71blksuper4x4 View Post
I will also measure my 157" Cab and Chassis C30 frame rails. That way we have a definite answer. I think we need to measure all the same way, in between the frame rails. Just so we are all the same. Trevor
Awesome Trevor, that would be fantastic. I've also asked BlueBullet to measure his Longhorn. I will go back and triple check the measurement of mine as well.
Dan
1970 C30- 350/SM465 133" WB, Soon to be a K series
1970 C10- LWB 250/3OTT, (sold)
1966 IH Scout 800- 152/T-90/Dana 20/ D27s
Turnip Truck is offline   Reply With Quote
Old 02-06-2018, 04:32 PM   #27
Jcfcamaro
Jcfcamaro's Avatar
Originally Posted by Turnip Truck View Post
Hmmm.. That's a good point. I will pull a thickness measurement on my frame rail ASAP. The only thing that has me confused is JFCs measurements on this K10 frame (which is what the cross member is designed for and advertised to fit). His measurements are the same as mine on the C30.
My measurements were takin inside the frame rail just in front of the stock cross member . On a k10 the frame has to be the same in that area or you wouldn't be able to slide it forward for the 6 cylinder location. Hope this helps.
Jcfcamaro is offline   Reply With Quote
Old 02-06-2018, 04:45 PM   #28
Turnip Truck
Right.. I think the frame should be the same height spanning the distance in between the lines below.
Name:  1TON FRAME 2.jpg
Dan
Old 02-06-2018, 05:02 PM   #29
BlueBullet
BlueBullet's Avatar
That measurement on mine is 5-1/8" on both sides. I measured right in front of engine cross member.
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 02-06-2018, 06:20 PM   #30
Turnip Truck
So here's my solution for those interested. Kert offered to make me some shorter parts to fit my frame, but that costs $$$, I also could've had it cnc milled locally, but that also costs $$$.
Here it is as received from DIY4X
I went to the shop and picked out my thickest chop saw blade
Name:  blade width.jpg
And sliced the pieces in half,
Name:  width of cut.jpg
Here's my height after the cut, just about perfect.
Now ill grind away some of that nice powdercoat, cut a V groove, square it up, and burn it back together with the Lincoln
Dan
Old 02-06-2018, 06:40 PM   #31
BlueBullet
BlueBullet's Avatar
Perfect!! That was going to be my suggestion if it came to it.
1967 Pontiac GTO
Old 02-07-2018, 02:32 PM   #32
Turnip Truck
I will clamp them in place inside the frame and tack it together in a few places before I weld them up completely. That way it will guarantee a perfect fit.
Dan
