Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 03-18-2018, 01:41 AM   #1
Evkev7
1990 TBI acts like it's loading up like a carb
K so my 90 Suburban has an on and off again issue of sort of stalling out just off idle, and sometimes at speed in town.
It's a 4 bolt main 5.7. Stock. I recently bought it back from a friend who put the engine in while he had it. It was running way bad when I got it back, acting like the fuel filter was plugged. I went thru a few filters then replaced all the sensors on the tbi from stuff from the junkyard, air idle sensor, EGR, throttle position. Seemed to totally seemed to fix it.
It's 99% better. But the off idle stumble is annoying.
It is on 35 inch tires with somewhat tall gears. If I drive in 2nd gear in town it doesn't do the load up thing. Keeping the rpms up keeps it happier.
Thoughts from the experts would be greatly appreciated.
Evkev7 is offline   Reply With Quote
Old 03-18-2018, 09:43 AM   #2
ChevyTech
Re: 1990 TBI acts like it's loading up like a carb
If it is loading up it could be running rich because of a bad coolant temp sensor.
There is testing information in post #11 of this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=379142
That thread can be found be looking in the frequently asked question thread from the top of this board.
http://67-72chevytrucks.com/vboard/s...d.php?t=445487
Old 03-18-2018, 12:49 PM   #3
Evkev7
That's the one sensor I didn't replace cause it looked brand new when I got it. Tho I've noticed it has a slight leak at the thermostat housing; I suppose that could be allowing a bit of air there at the sensor once it's been running huh?
Ill test it today.
Thanks!
Old 03-18-2018, 01:50 PM   #4
Bigdav160
Bigdav160's Avatar
This is where a good OBD1 scan tool is useful.
Where do you have your ignition timing set at?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-18-2018, 08:08 PM   #5
Evkev7
It never throws any codes. I jumped the plug and checked that way.
Haven't checked timing it runs awesome 99.99 % of the time so timings not the issue. I put a coolant sensor in today just to see if it did anything. Its hard to pin down cause it's so intermittent. But it's also not a big prob cause it's so intermittent lol.
You mess with the duck and you might get the bill!
1990 GMC Suburb
84 GMC half ton
1975 GMC 4x4
66 El Camino
Copyright ©2000 - 2018, vBulletin Solutions Inc.
