88-91 LED Moonie Cluster mod
This topic is now an FAQ-"88-91 LED Moonie Cluster mod"
Just thought I'd share the results of one of today's projects... ![]() Last edited by 1badgmc; 02-27-2011 at 01:37 PM. |
88-94 LED Cluster mod
I didn't take any pictures of the actual removal of the cluster from the truck, but I'll go ahead and give the steps for those who might be interested.
- There are 4 T15 Torx screws holding the dash bezel on. Remove those and you can pull the bezel out. If you have an automatic, you'll probably want to put the shifter in Low 1 to get it out of the way. My truck is a 5-speed, so I don't have to bother with it. - Once you get the bezel loose, unplug the headlight and dimmer switches. - Remove the bezel and set it aside. - Remove the 4 7mm screws holding the HVAC controller. - Remove the 3 7mm screws holding the radio (or the pocket in my case). - You don't have to remove these items, but they need to be loose so you can access some of the screws holding the cluster. - The cluster has 4 7mm screws holding it on. Remove them. - You can now remove the clear plastic shield and set it aside. - The cluster is ready to come out. Just pull on it and it will slide out. - So now you are here... ![]() - There are 10 T15 Torx screws holding the individual gauges to the panel; 4 for the speedometer and 3 on each side for the smaller gauges. Remove them... ![]() - The gauges are plugged into the board, but they are now ready to just pull out. The speedometer comes out first... ![]() - Then the 2 top gauges can come out... ![]() - And now the bottom 2 can come out. Once they're out, you can see the 5 bulbs that provide the main cluster lighting... ![]() - Pull those bulbs out and plug in your LEDs. I used the WLED-HP5s from Super Bright LEDs... ![]() - After installing your LEDs and before you put the cluster back together, go back to the truck and install the cluster and then plug in the headlight switch. Turn them on to make sure all of your LEDs are lit up. The LEDs are polarity sensitive, so if one doesn't light up, unplug it and turn it around and then it should work. NOTE: For blue or green LEDs, you are now ready to start putting everything back together. If you want red, white or amber and want the colors to show purely, you'll need to trim the green from the back of the gauges. This is what it looks like... ![]() I would suggest a Dremel or other similar hobby tool to carefully trim it off. Don't go too crazy, though, as the edges are needed to hold the gauges together and to mount them to the board. - Now reverse the process to put everything back together and enjoy your new nighttime look... ![]() ![]() ![]() Last edited by 1badgmc; 02-27-2011 at 02:00 PM. |
The LEDs were $5.95 each. There are 5 of them. There are less expensive alternatives, but I wanted the high power SMD LEDs for mine, so I spent the money for them.
It really is pretty simple. Due to having to actually dig into the cluster and pull the gauges out, it's not quite as simple as the same job on a '96-'98 cluster, but it is a very basic job. I kept waiting around for someone on some forums to give proper info on how to do the job on the moonie gauges, but it never happened. Plenty of people were doing the work on '91-'94 needle clusters and trying to apply that same information to the moonies, but that's just not the case. I had a little extra money for some LEDs and the truck isn't leaving the garage anytime soon, so I figured I'd tear into it and figure it out for myself. Last edited by N2TRUX; 02-27-2011 at 12:12 PM. |
Happy to be here
![]() ![]() Join Date: Mar 2000
Re: 88-91 LED Cluster mod
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-27-2011 at 02:35 PM. |
Re: 88-91 LED Moonie Cluster mod
Hey chaps, I am new to this forum and I must say I love it. It has been very helpful so far.
Thanks 1badgmc for this mod it is fantastic and easy to do with the instructions given. I have just received my LEDs and installed them.....I also replaced the one high beam lamp as well as the 5 dash lamps, all with blue. I am getting the dimmer to work too, not very defined but it is working. Q: How do I know if the oil pressure gauge is working??? I think it is not, after putting the dash back in. Has any one else come across this?? If you would like to see my pictures please click - http://lukegoleman.blogspot.com Thanks Air |
#6 | |
error 404
![]() 89 Chevy swb 350 "SJ" DD turned parts truck. SOLD 90 Chevy ext cab loooongbed. "storm trooper" Rust In Peace. 06 Kia sorento wife's car 06 charger srt8 "lucifer" my toy '12 Kia optima |
error 404
why are air's leds and 1 bads looking so different. air's have really bad hot spots. sup with that?
#8 | |
![]() Thanks Air |
error 404
i mean it looks good. but i want to do this same thing. with color blindness i cant see the speedo very well so it would be a plus. it might just be the picture quality. it looks different on the top part of the speedo kinda blurry almost.
#10 | |
May be 1bad can share his thoughts?? Air |
#11 | |
Cameras can play tricks on you depending on the exposure settings of the shot. I can set a camera to take pics of a cluster with hot spots all over the place and make you think that it doesn't have any, but I try to make my shots as honest as possible. When you look at my cluster with the naked eye, there are no hot spots at all. It looks just as good as in my pics. It's really puzzling since you and I both used the same blue HP5s from the same place. Are your bulbs arranged the same way inside the cluster as mine are? In all the same locations as mine? Last edited by 1badgmc; 03-03-2011 at 09:28 PM. |
#12 | |
![]() Ah well it really makes no difference to me, the color is great and I can now see them well in the dark. I love it, the money was well spent ![]() Thanks for the write up man! Air Last edited by Airdinamic; 03-03-2011 at 10:08 PM. |
#13 |
error 404
been going back and forth on this for a while, 1bad introduced me to the idea actually. its worth a try i guess. hopefully it turns out ok. but anything is an improvement
#14 |
![]() Join Date: Nov 2009
so glad you did this, ive been waiting for someone to do it first lol thanks!
1979 chevy blazer 2wd drop spindles shackles new paint wheels tires custom one of badges cut on waterjet brakes exhaust carpet 2" cowl hood window seals misc weather seals door panels crate 350 w/ 67k turbo 350 3.08 rear end gear ratio FOR SALE! http://67-72chevytrucks.com/vboard/c...ct=4838&cat=13 |
#15 |
I got tired of waiting for someone else to do it first.
#16 |
error 404
to anyone that wwants to try digital gauges. if you live in a colder climate i would say below 0 in winter. and your truck is parked outside. dont buy digital it will freeze and crack rendering it useless. atleast thats my expierence.
edit: 1bad PM me if you have ever had isssues with you heater control. as far as changing from floor to defrost to regular vents.
![]() 89 Chevy swb 350 "SJ" DD turned parts truck. SOLD 90 Chevy ext cab loooongbed. "storm trooper" Rust In Peace. 06 Kia sorento wife's car 06 charger srt8 "lucifer" my toy '12 Kia optima Last edited by 89chevsj; 03-05-2011 at 03:38 AM. |
#17 |
Thanks for the info!
Damn Boys We're in a Tight Spot! |
#18 |
it says for the pickups.....but will this also work for an 88 chevy s10 blazer?
#19 |
I'm sure you can get similar results by replacing the cluster lighting with LEDs in an S10 Blazer, but I've never touched one so I can tell you nothing about the process of actually swapping them out.
#20 |
I did this mod last fall and put blue LEDs in my 89 chevy 1500. I wasn't sure if I would need to trim the green plastic or not, so I bought an extra instrument cluster off of Ebay and trimmed the green on them. Worked great. I don't think I needed to trim them for the blue lights though, so I'm probably going to put my original uncut gauges back in sometime in the next month or so. If anyone is looking for a full set of working gauges that already has the green plastic trimmed, let me know, and I'll keep you in mind. When I trimmed them, I was concerned that I might slip with the dremel tool, so I melted out the unnecessary plastic with a wood burner, nice and slow. It worked quite well.
Tav |
#21 |
ok so i just took my dash and it was nothing like that.....i have an 88 s10 blazer and the dash is COMPLETELY different. . But at the same time i took everything out just to see how it works and to make sure im gonna buy the right bulbs.......i put it back together fine...it actually wasnt too hard although for a while none of the gauges worked lol
#22 |
Old Skool Club
![]() Join Date: Jun 2001
There's a separate forum for you Dimer's. Your truck isn't going to be the same as ours.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#23 |
error 404
but the general concept is. if your gauges stopped working after adding a direct replacement bulb...ya done somethin wrong.
#24 |
Trailers are for BOATS!
What about changing the colors on the hvac display? Is that possible?
The Rod Barons C.C. CSA ![]() |
#25 |
It is, but I haven't bothered with it. I forget what bulbs are required for the button illumination. To change the color of the display, you can buy a sheet of colored plastic and cut it to match.
Thread Tools | |
Display Modes | |
