Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 01-05-2018, 09:13 PM   #1
ChevyTech
Answer to MaddMech EGR private message
MaddMech sent me a private message but can not receive a return message.
Here is what I get when I tried to reply to the message sent to me:
MaddMech has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her.
To answer the question MaddMech sent me for a hesitation on a 93 C3500 5.7 stock and a NV4500 tranny. P/N on EGR is 1708718
That EGR number is a port EGR valve.
The EGR solenoid should have three wires to it, instead of two like the negative back pressure EGR trucks have
That EGR valve is a simple diaphram and should open when you put vacuum on it with the engine running or not.
All the modulation on that system is done with the EGR solenoid which is referred to as a EVRV
The only way Port EGR causes a hesitation is if the valve is sticking open or the EVRV has issues which can happen if dirt gets sucked into it and makes it stick at times. Make sure no vacuum can get through the EVRV with the engine at idle.
If I were working on your truck the first thing I would do is test the fuel pressure with the engine running.
Old 01-07-2018, 08:43 PM   #2
LT7A
Re: Answer to MaddMech EGR private message
They might have a full mailbox.
Old 03-30-2018, 07:56 PM   #3
MaddMech
Thank you Chevy tech. I did not know that I had private messages blocked, but I think I got that corrected. Any way, I checked vacuum at TBI: 0 at idle and up 20" at more than 1/4 throttle. Checked EGR bi applying vacuum and holds with no leak down. At idle if I move diaphragm the engines stumbles and almost dies. The only thing I see is that at idle with the vacuum gauge now hooked on EGR side of solenoid when I move the throttle, the most I get is just shy of 1" vacuum. I swapped out another, used, solenoid with the same results. I guess it must be a wiring problem. NOTE: I did check fuel pressure running. Had 9.5 at idle or WOT. Changed filter and have 11.5-12.0 at idle or WOT. I have installed fuel pressure port at TBI drivers side fuel line. Timing is at 4 BTDC. New plugs and wires, cap and rotor. It has a 369 ICM installed.
MaddMech is offline   Reply With Quote
Old 03-30-2018, 10:52 PM   #4
95 S_Trucker
95 S_Trucker's Avatar
Timing should be set to 0 degrees with the timing connector disconnected.
-99 K2500 LS CCSB 7.4
-11 GMC 2500HD SLE CCSB 6.0
-96 C3500 HD 7.4 NV4500 Rollback
-85 K10 5.7 700r4
-78 K10 5.7 4 Speed
-90 ZR1 5.7 6 Speed
-62 Lincoln Sedan 430 Auto
-61 Lincoln Convertable 430 Auto
85 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=368864
78 Big10 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=383629
96 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=614515
95 S_Trucker is offline   Reply With Quote
Old 03-31-2018, 09:12 PM   #5
ChevyTech
Everything looks ok except the timing.
Put the timing at zero as stated with the connector unplugged.
What problem are you having with the truck?
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
