Old 03-22-2018, 07:14 PM   #1
Signuil282
4.3 to 5.7 swapp
I have a 92 sierra 4.3 and dropped a 94 chevy 5.7. Left all the harness for the 4.3 but it runs very rough and won't even idle...any suggestions?
Should I put a carburator?
Signuil282 is offline   Reply With Quote
Old 03-22-2018, 09:31 PM   #2
b454rat
Re: 4.3 to 5.7 swapp
Put the 350 ECM in?
Old 03-23-2018, 08:54 AM   #3
Signuil282
My mechanic said the 350 rpm won't plug in he said it is different
Old 03-23-2018, 09:33 AM   #4
Since you were told the ECM won't interchange, maybe you can get a new program chip for your current ECM.
1981 GMC High Sierra SWB Stepside
2006 GMC Sierra 1500 SWB W/T
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Old 03-23-2018, 10:23 AM   #5
Signuil282
I really appreciate all of the valuuable info. Now the question is how do I get a new program chip?
Old 03-23-2018, 03:18 PM   #6
I am told you can order them thru AutoZone or other parts place. But normally they need the serial number so it can be programmed for the exact vehicle. Hopefully some one will speak up, there is someone that a few folks used to have their ecu reprogrammed, but I can't find the info right now.
Board Vendors
Old 03-29-2018, 06:20 AM   #7
lofly'a
lofly'a's Avatar
i did the 4.3 to 5.7 swap 6 years ago, all you need is the 350 chip for the operating parameters. you could swap the whole computer but not necessary. anybody tell you otherwise is stringing you along.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-94 Cheyenne (350/4L60E) 5/6 drop JUST FOR FUN
lofly'a is offline   Reply With Quote
Old 03-29-2018, 09:43 AM   #8
Signuil282
Thanks, I have swapped the chip only and it did not run very welll...i swapped the whole computer and it does at least run down the road
Still sputter but stays running. After a little while of running I did notice it runs ok with a miss when I first start it but then wants to stall out when I give it gas. I must have a different problem other than just the computer
Old 03-29-2018, 11:19 PM   #9
1967GTO
Did the timing get set correctly with the connector disconnected?
1967GTO is offline   Reply With Quote
Old 04-04-2018, 09:54 AM   #10
lofly'a
lofly'a's Avatar
sounds like the original ECM was bad.
Old 04-04-2018, 11:51 AM   #11
Signuil282
Looks like the timing was off just a bit. Also, when I disconnected the egr hose from the sensor above the valve cover it ran so much better....
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
