07-08-2021, 02:56 PM | #1 |
Which Air Breather - & - what engine did the dual air breather come from?
While I was going through more of my parts I ran across this dual air breather. I forgot I even had this. But it fits. Soooo...
a) Which breather looks best? b) What engine did the dual breather come from? Thanks
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
07-08-2021, 03:04 PM | #2 |
Re: Which Air Breather - & - what engine did the dual air breather come from?
Likely came from a Camaro (even into the 80's) or a Corvette.
Both look good to me!!! |
07-08-2021, 03:16 PM | #3 |
To me, the dual one says "more power" and that's what I'd use even if it did not warrant it. I might even put in a bit taller filter to let some of the carb noise out under hard pedal.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
07-08-2021, 05:14 PM | #4 |
Looks like the 1980's Ram Air L69 Z-28 Camaro Air Cleaner although the lid might mean I'm wrong...
I was wrong. looks to be 78 79 80 81 Corvette air cleaner 350 L82 L48 1978 1981 dual snorkel it has that left side snorkel that dips down a bit.
MusicMan70 1961 GMC Suburban Last edited by MusicMan70; 07-08-2021 at 05:21 PM. |
07-08-2021, 10:03 PM | #5 |
Who Changed This?
I like the dual snorkels, but that's probably overkill for a stock build. GM put partially open elements on a lot of hot rods, the Corvette and Z-28 Camaros being classic examples. More, cooler air available is always better. Off-brand, but I had an '05 Corolla that I put cold air induction on (took out one of the blanking plates for driving lights, which I had not bought when I got the car). I could pull hills better and gained .4 MPG. Doesn't seem like a lot until you drive a vehicle a 1/4 million miles. Made it out of less than $8 worth of ABS drain pipe pieces. I want to run a cold air induction system on my truck, but that's way down the list of things that life requires me to do.
07-09-2021, 12:14 AM | #6 |
It is a "78 79 80 81" Corvette air cleaner 350 for the L82 motor.
Earlier versions didn't have the hot air bypass. Rick |
07-09-2021, 12:28 PM | #7 |
70+ ( Old Skool Club )
I bought mine from Rock Auto and application was for a 1972 Z28 Camaro. Been on for 5 years now with no issues. Even had the provision for that spark arrester thing that goes from the air cleaner to valve cover on passenger side rear. I also like that its smooth and doesn't have the flap doors on the snorkels.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
07-09-2021, 06:00 PM | #8 |
I just made my own by tack welding another snorkel onto mine.
You can see the tack welds on the snorkel on the left.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW Last edited by Caddylackn; 07-09-2021 at 06:01 PM. Reason: added text |
07-09-2021, 06:23 PM | #9 |
Who Changed This?
^ Yup, I did that on my '69 Camaro.
