12-21-2018, 03:02 AM | #1 |
HEI Module Paste
Where can I get a tube or small packets of the white insulating paste you're supposed to smear on the bottom of the Ignition Control Module in an HEI distributor?
You get one free with every new ICM, and the local auto parts stores used to have a little katchup packet size for sale on the sides of the cash registers, but I could not find it at my local O'Reilly's nor Auto Zone. It looks just like white lithium grease, but I'm told that's not it. Also the Ky Jelly-like silicone dielectric grease [used on HEI plug wire and plug ends] is also not the right stuff. The Modules get hot, and this stuff is supposed to insulate it from the deck of the distributor. I've been told it's used in computers and you can get it at computer shops, but that world is a mystery to me. I have a couple of spare, used, checked-OK modules, that I keep in the glove boxes of my trucks, but no fresh white gunk. So what do you call it and who's got some?
12-21-2018, 09:28 AM | #2 |
Old member
Re: HEI Module Paste
Autozone also has the Heatsink Gel and its Wells part number is SL203.
If you have a store around. They all closed down here in SC. The Radio Shack part number is 276-1372. https://www.autozone.com/miscellaneo...ound/19189_0_0
12-21-2018, 10:52 AM | #3 |
On computers they call it thermal paste
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
12-21-2018, 01:41 PM | #4 |
I buy thermal paste on Amazon. It comes in a syringe so it's easy to apply exactly where you want it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-21-2018, 01:44 PM | #5 | |
Radio Shacks have disappeared here. They have an online operation, but the good ol' days of going into the Shack with a sick CB rig and coming out with a perfectly tuned 2-way are long gone. Looks like they're out of 275-1372 anyway. rpmerf, thanks.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 12-21-2018 at 01:57 PM. |
12-21-2018, 02:01 PM | #6 |
Amazon. Right. I should get a big tube for tune-ups. But I want a couple of the catsup packets in the glove box for emergencies
12-21-2018, 03:38 PM | #7 |
I think folks are misunderstanding what this paste does. It isn't an insulating compound but just the opposite. It makes a better heat connection between the module and the dizzy base so heat generated in the module can flow into the metal base of the dizzy and then into the air. No paste = too hot module = early fail.
If you are swapping modules, be sure to remove all the old paste before installing new module + paste. The paste fills the small imperfections in the metal surfaces between the two surfaces and allows for better heat flow. Too much paste is bad as well. |
12-21-2018, 05:58 PM | #8 |
My local AutoZone said to use white lithium or silicon dielectric. That's the same store who first said the modules couldn't be tested, but they sold new ones. I had to show them how to use their diagnostic machine.
Do later distributors not have a module? Even later engines don't have a distributor, I guess. There seems to be a lot of ignorance and misunderstanding about this substance. I'm proud to be associated with this Board.
12-23-2018, 06:28 PM | #9 | |
12-24-2018, 03:57 PM | #10 |
I went to buy a new module and found that the two brands that Oreilley's carry only come with silicone dielectric. Wonder if this is a trend. The bad module I pulled off only had silicone on it...No wonder it failed.
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
12-24-2018, 07:01 PM | #11 |
It is in the parts shop's and in the manufacturer's best interest to sell you as many modules as they can. Failure boosts their economy. They are banking on Radio Shack's going out of business and making heat sink compound harder to find unless you know what to look for.
12-24-2018, 07:06 PM | #12 |
And by the way, a thin coat of that silicone dielectric on the terminals of the module is probably a good idea, so they are giving you the silicone dielectric for that purpose and just not giving you the most important heat sink compound for under the module.
12-26-2018, 10:14 PM | #13 | ||
The Older Generation
I also use the computer CPU thermal paste. https://www.newegg.com/Product/Produ...-007-_-Product Best thermal paste you can get. Those processors really get hot. Dispenser has a rubber cap on the end so you can still keep it in your glove box. Quote:
12-26-2018, 11:24 PM | #14 |
So with Andy's p/n, I went back to my local AutoZone. And sure enough, way in the back they had one last box. I bought it, and it had 2 very small packets inside. So I can put an ICM survival kit in each glovebox of my 2 trucks.
Now that the xmas rush is over I will get a big syringe for the tune-up kitbox. Thanks for your expertise, Gentlemen. ElDoradoJim, look closer, the silicon di-electric is NOT the right stuff. Under the ICM you want this heat sink paste, not di-electric grease.
