Old 04-10-2018, 04:29 PM   #26
dsraven
Re: 1950 Rear Bumper Brackets (non Drop)
you really are a sicko, I KNEW it.
nice. are those all your cars? cool space. I sorta plan to do something a little cleaner with my garage after I get this truck finished.
Old 04-10-2018, 04:37 PM   #27
Curt - TN
Thanks, I am lucky and my wife shares my car passion so it is a He & She Cave.
These are the old ones we currently have are, I need to get the 50 done and sold so I can finish my the rest of my keepers:
1950 Chevy Truck - The one in this thread
1960 Corvette - Completed
1931 Auburn Phaeton - Completed
1933 Auburn Speedster Boattail - Under restoration
1963 Corvette Split Window Restomod (custom chassis C5 Corvette LS3) - Under restoration
1957 GMC Big Window Restomode (custom chassis C4 Corvette and LS2 under it) - Under restoration
Curt
Brentwood TN
1950 Chevy 5 Window 3100 - Check out my Build Thread: http://67-72chevytrucks.com/vboard/showthread.php?t=724260
1957 GMC 100
Curt - TN is offline   Reply With Quote
Old 04-11-2018, 10:17 PM   #28
Curt - TN
OK, here is an update:
My wife and I went to the shop and pulled the bumper off. We left the brackets on the bumper and just flipped it and slid it back into the frame rails. We were able to get the two bolts closest to the rear in and it left the bumper angled down a little because if we raise it up the bumper brackets hit the bottom of the bed.
I like the height now so I have two options. First I could trim a notch in the top of the bumper bracket so that I can raise it up enough to get the inner bolts in or I just bite the bullet and make a new bracket.
This at least gets the bumper positioned so I can take it in for exhaust on Friday
It defiantly looks better up higher but when I can get it outside I need to spray the tank black then it should hide the tank pretty good.
Thanks for all of the ideas and feedback!
Curt
Brentwood TN
1957 GMC 100
Old 04-11-2018, 11:19 PM   #29
mongocanfly
muchly improved....looks way better..
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 04-11-2018, 11:52 PM   #30
Fred n' Ethel
Fred n' Ethel's Avatar
Greg's pic in post #8 shows the brackets on the outside of the frame channel.
On my 54 they are mounted on the inside of the channel with what looks like an alignment dimple between the bolts.
Would lowering the brackets to the bottom lip of the rails and drilling new holes in the frame rails give you enough clearance and be positioned satisfactorily ?
It does look a lot nicer up there.
Fred n' Ethel is offline   Reply With Quote
Old 04-12-2018, 08:18 AM   #31
Curt - TN
Mine were also on the inside of the frame rail, not sure I could have stretched them to the outside.
Curt
Brentwood TN
1957 GMC 100
Old 04-12-2018, 11:20 AM   #32
youngrodder
youngrodder's Avatar
Weird....I wonder if I have mine mounted incorrect. On my 53 Suburban I have them mounted on the outside of the rails. It fits tight and the mock up bumper that I'm using is bent so I figures that was why it fit tight.
Marc
............................... ____
.................. _______ |___\____
..;.;;.:;:;.,;. |__(O)_| ___ /_(O)|
1948 Chevy Truck - Finished
1953 Chevy Suburban "Family Truckster"
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
youngrodder is offline   Reply With Quote
Old 04-12-2018, 09:20 PM   #33
NeoJuice
Here is what I was planning on doing. The video is called rear bumper tuck. Hope this helps you out.
https://www.youtube.com/watch?v=XxHbuD9XLDo
NeoJuice is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
