Old 03-31-2018, 11:02 PM   #1
kipps
shifting nv4500 vs sm465
I've read that a early 90's nv4500 shifts harder than the later 90's and early 2000's ones.
When was the change made?
Are the early "hard-shifting" nv's any worse shifting than a sm465?
kipps is offline   Reply With Quote
Old 03-31-2018, 11:05 PM   #2
mongocanfly
mongocanfly's Avatar
Re: shifting nv4500 vs sm465
the design changed in 96 I believe...no experience with the early ones but mine shifts easy..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-31-2018, 11:10 PM   #3
SunSoaked
SunSoaked's Avatar
My 94 shifts smooth and easy. At least it did when I test drove it before pulling it. In the process of swapping it into my 85 K20 still...
SunSoaked is offline   Reply With Quote
Old 04-01-2018, 11:25 AM   #4
B. W.
B. W.'s Avatar
I've driven both early & late in more that a few rigs (only one was mine) and never really felt a difference. If one did shift hard I attributed it to the clutch or the gear lube. It may be an issue but I never perceived it. If I were buying one I wouldn't be concerned about it.
They all shifted better than the 465, with that said, I think the 465 shifts fine.
B. W. is offline   Reply With Quote
Old 04-04-2018, 11:26 PM   #5
'63GENIII
'63GENIII's Avatar
^^^This.
My beat up 465 shifted great once I learned it's personality. If it didn't shift well, it was user error.
That said, my early 4500 shifts like I would think a Porsche would compared to the 456. Never drove a later model but would expect the same or better.
I have heard that the round tower transmissions "can" be prone to dragging the shift forks if the shift stub "ball" starts wearing into the top cover. I have heard that the square top (later 4500) design eliminates this possibility. Again, Ive only heard this and not experienced it firsthand.
FWIW, my 4500 was rode hard and put away wet when I got it. If any transmission could have been worn at the stub shift ball, it would have been that one.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
