Old 05-17-2017, 08:28 PM   #1
First c10
First c10's Avatar
Rear axle centering to bed wheel well
Hey guys has anyone cut the front of the bed so the axle/wheel was centered in the bed wheel well?
I was told that with a load the axle moves back. But that means it is always off center like 95% of the time and fine when you have a load in bed or when towing. 5% or less. My truck will probably never have a load in it.
So I was thinking of cutting a pie shape out of the front and moving the lip forward 1"
If you have a link or a place where you have see it or done it please let me know.
Thank you
Scott
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 05-17-2017, 08:58 PM   #2
Re: Rear axle centering to bed wheel well
Leave it alone, don't let it bother you. These trucks are immaculate beings, hence the humongous following that continues to grow after all these years
Old 05-18-2017, 11:28 AM   #3
ct67_72
ct67_72's Avatar
Why not use an adjustable spring perch and move the axle into position?
Dan.
Drivetrain parts and accessories.
68 medium green shortbed fleetside
ct67_72 is offline   Reply With Quote
Old 05-18-2017, 11:41 AM   #4
BLT gmc
Look at the "axle off set plates" offered by Off Road Design.com.
BLT gmc is offline   Reply With Quote
Old 05-18-2017, 11:49 AM   #5
Jstock85
You're splitting hairs Scott! If its bothering you that much go the suspension route. You are probably a lot better than me but when i start "cutting" bad things happen...
Jstock85 is offline   Reply With Quote
Old 05-18-2017, 01:50 PM   #6
demian5
demian5's Avatar
Looks fine.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-18-2017, 06:08 PM   #7
First c10
First c10's Avatar
I have already moved the axle backwards due to the shackle flip kit. It is at the correct location for stock. My question was has anyone cut the fender to make it even?
Thanks for the replies
GO GO!!!
Old 05-18-2017, 11:27 PM   #8
I used to cut them to clear bigger tires than you have with less lift when I rode them hard and put them away wet years ago
Old 05-18-2017, 11:51 PM   #9
First c10
First c10's Avatar
Looks even!!! Lol. Big tires on that truck. Looks like a fun time.
Appreciate the comments. Looking to do a few things that are subtle but custom.
GO GO!!!
Old 05-19-2017, 08:16 AM   #10
Mike C
Mike C's Avatar
I cut a pie piece out of my Jimmy. It's about 6" long and 5/8" wide at the very bottom. This makes the wheel well almost perfectly round removing the "hook". I also re-drilled the perches on my 9.5" sf 14 bolt to move it back. I needed to move mine as much for the custom driveshaft I had made for the 12 bolt because the nose of the 14 was longer. But it is centered quite well and doesn't grab the lip on big bumps any more.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-19-2017, 10:57 AM   #11
First c10
First c10's Avatar
any photos???
GO GO!!!
Old 05-19-2017, 10:50 PM   #12
You mean looks even worse? LOL!!! That was a mountain farm truck when I got it, already had all that rust in '82. That mud is inside the windows. I had my windows open romping through rocker high mud and water. Also broke an outer shaft that night before... DOH! I had the neauty and the beast thing going on there.
I've seen wheel openings "radiused" to look factory. I think shifting the axle is your best bet, w/o getting into complex body work
Old 05-19-2017, 11:24 PM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Without them being "offset"... to me they would look weird.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-20-2017, 08:28 AM   #14
Mike C
Mike C's Avatar
any photos???
I'll see what I can do this weekend if the weather cooperates.
44 Willys MB
52 M38A1
64 Corvette Coupe
