07-23-2017, 09:33 PM | #1 |
1969 K10 Cigarette Lighter Wiring
I'm in the middle of rewiring my '69 K10 and have hit a snag at the cigarette lighter. See image of back of cigarette lighter, which has two old wires headed to it (one to the center threaded post, the other to the offset component). The AAW harness just has one orange wire with a very different connector intended for the post style. Advice? I'm not relying on the old wiring or components being original as it was a mutt of a truck and the wires leading to the old cigarette lighter were multiple frayed wires daisy chained in series.
07-23-2017, 10:01 PM | #2 |
Re: 1969 K10 Cigarette Lighter Wiring
Don't know about the wires, but need to see the answer! A DIN radio? That hurts...
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
07-23-2017, 10:15 PM | #3 |
The new harness is correct. It (the positive wire) should connect to a pin-like center post. It looks like someone replaced the lighter socket. An original socket shouldn't require a ground wire (your second wire) since the socket grounds to the dash.
07-24-2017, 08:50 AM | #4 |
The other component appears to be a light socket
07-25-2017, 09:52 AM | #5 |
Old member
This is the correct connection for these modle trucks for the hot wire to the lighter.
The lighter looks like Bigdav160 said. A aftermarket light for it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
