Old 07-27-2016, 10:25 PM   #26
ironman3452
ironman3452's Avatar
Re: 1960 - 1965 Steering Wheels
here is mine in my 64 chevy panel
ironman3452 is offline   Reply With Quote
Old 07-29-2016, 04:57 PM   #27
oldusafmsgt
oldusafmsgt's Avatar
Custom wheel in a factory original 1960 C10. The wheel came from a 61.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 07-29-2016, 05:07 PM   #28
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Old 04-27-2017, 09:30 AM   #29
kevinjr
After all the fine comments .My question is? Was there any other direct fit smaller diameter steering wheels from cars that will replace the giant steering wheels of 1964-66 C 10 trucks .?With a working horn
kevinjr is offline   Reply With Quote
Old 04-28-2017, 04:16 PM   #30
Doug66
I don't know, but the internal horn connection parts from my 66 Chevelle is the same as my 66 truck. The wheels are the same diameter however. I would look up the horn replacement kit with a supplier that is the same as your truck then match a smaller wheel that uses the same kit.
Doug66 is offline   Reply With Quote
Old 04-29-2017, 12:49 PM   #31
61K10
61K10's Avatar
So the 66 tks had a smaller wheel than my 61?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-29-2017, 12:52 PM   #32
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
I installed a 65 El Camino steering wheel in my 66-10, I haven't hook up the horn yet but I do like the smaller wheel....
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 04-29-2017, 07:40 PM   #33
kevinjr
what is the OD measurement across
Old 04-30-2017, 05:14 AM   #34
Doug66
No. What I said is you could find a smaller wheel that uses the same horn internal parts. The wheels are the same diameter at about 16 1/2". Take a look at the El Camino wheel as the thread above suggests...
Old 05-02-2017, 12:27 AM   #35
cgrocen
Here is a custom steering wheel in a 1966 GMC. I am pretty sure it is a Canadian GMC, as it is in Saskatchewan. Since the wheel appears to be a different color than the column, it may have been changed at some point in the past by a previous owner.
[IMG]hébergeur d images gratuitcertificity.com[/IMG]
cgrocen is offline   Reply With Quote
Old 05-02-2017, 04:24 AM   #36
Doug66
That steering wheel design was originally installed on 1960 Chevrolet Bel Airs (not Impalas) and later installed on the 1964 Custom Cab C10 Chevy pickup trucks. BTW, my 66 Custom Cab C10 was originally fitted with a 1965 Chevy Nova steering wheel as Chevy was upgrading their trucks and reaching back to earlier models to save cost. Google 1960 Bel Airs and take a look at the interiors.
Old 05-02-2017, 04:19 PM   #37
60-66
60-66's Avatar
That steering wheel was used in 1959 AND 1960 Biscayne and Bel Air .1961 Chevys trucks used this wheel also but it was Silver, White was used in 1962 and 1963 and part of 1964 in Chevy Trucks only. 1964 and 1965 Chevy custom wheels were fawn. GMCs never had a custom steering wheel , just the standard Chevy steering wheel 1960-1966.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is online now   Reply With Quote
Old 05-14-2017, 10:34 PM   #38
jrusher
Im looking for a stock steering wheel for my 65 c10 auto trans custom. Are the 3 on the tree steering wheels compatible with the automatic columns? Thx in advance for any info
jrusher is offline   Reply With Quote
Old 05-14-2017, 11:00 PM   #39
60-66
60-66's Avatar
Hi ,Yes , you could get a Custom wheel on any of the factory columns for 65 , no difference in the wheel to the columns
Old 05-14-2017, 11:22 PM   #40
jrusher
Okay great just picked this truck up drove it from Oklahoma to Alberta Canada was a long trip . Has a smaller grant aftermarket wheel and wanna go back to more of factory wheel . Are other years compatible as well ? Just reading some impala and chevy II wheels will work too .
Old 05-16-2017, 01:21 PM   #41
gulfcoast66
64-66 CHEVY JUNKIE
My Original Wheel O.D size is about 17 1/2 . The Steering wheel I installed is 16 1/2 from a 65 El Camino, Malibu, Chevy ll car it's Smaller than the O.G. wheel. The mounting holes all line up with the O.G Steering column...
Old 05-16-2017, 01:28 PM   #42
65chevysub
65chevysub's Avatar
Originally Posted by Doug66 View Post
I am trying to identify the CUSTOM truck model steering wheel(s) for 1960 thru 1965 Chevy C10 trucks. I have some information that the pictured steering wheel is correct for 60 - 65 CUSTOM trucks. Can someone please tell me if that is correct or just what years this wheel is correct for? I know they were on Custom 64's. Thank you very much!
Thats the one I have on my 65 Suburban. The only other one I've seen is the non custom one that has the Chevy II emblem in the center. The custom one was also used on the 59&60 Impalas as well.
65chevysub is offline   Reply With Quote
Old 05-16-2017, 01:36 PM   #43
gulfcoast66
64-66 CHEVY JUNKIE
Here it is before and after I installed it.......
Old 05-17-2017, 08:45 PM   #44
cgrocen
Here is what appears to be a custom steering wheel in a 1965 GMC 910. It is another Canadian truck in Saskatchewan. This steering wheel matches the column. Could this be a Canadian thing for Custom wheels in GMC trucks?
heberger image
Old 05-20-2017, 11:29 AM   #45
oldusafmsgt
Factory original 1960 C10 with custom comfort option. Standard wheel.
Old 06-15-2017, 02:30 PM   #46
Darelray
New Member
What Car did that smaller wheel come out of?
Darelray is offline   Reply With Quote
Old 06-24-2020, 04:40 PM   #47
Tom Tarlazzi
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Tom Tarlazzi is offline   Reply With Quote
Old 06-24-2020, 06:19 PM   #48
Asshat
Asshat's Avatar
1963 C20 with Custom Comfort seat option. Not sure about the steering wheel.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
