Old 04-28-2021, 02:36 PM   #1
KyFarm
KyFarm's Avatar
Lower hose vs. alternator
Is it possible to find a lower hose that will fit radiator to water pump with the alternator in the mid-mount position?
KyFarm is offline   Reply With Quote
Old 04-28-2021, 02:48 PM   #2
kwmech
Re: Lower hose vs. alternator
I'd put the alternator where it belongs so it doesn't get splashed with water and crud in the winter. But that's just me
Old 04-28-2021, 03:33 PM   #3
KyFarm
KyFarm's Avatar
thanks for that, i'd say you were right. Not sure why they even sell these mid-mount brackets.
Do you happen to have a lower rad. hose part # for me?
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
Old 04-28-2021, 07:45 PM   #4
Rickysnickers
Easter to see
Old 04-29-2021, 01:55 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Considering the alternator on all V-8 67-72 trucks was on the drivers side with a short water pump, it looks like you'll have to come up with a different solution than a stock hose.
You could bend a wire coat hangar, or other hunk of sturdy wire, in the shape and length you'll need and head to the parts store to see what you can compare it to for fitment.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-29-2021, 05:18 PM   #6
gpgofast
Gates 21849....
gpgofast is offline   Reply With Quote
Old 04-30-2021, 04:48 PM   #7
KyFarm
KyFarm's Avatar
Originally Posted by gpgofast View Post
Gates 21849....
Thanks for that. A starting point is just what I needed.
Is that some sort of extension coming off the water pump?
Old 04-30-2021, 04:54 PM   #8
gpgofast
It's an adapter so I can have a temperature sensor for my fan control. I cut the hose DOWN to make the adapter fit. The hose fits perfect without the adapter I added.
Here is a link to a youtube video on wiring the fans. I used a BMW temperature sensor.
https://www.youtube.com/watch?v=nAKn...ndex=40&t=740s
Here is a link to the BMW switch. I used a 81/88 Deg C switch and wiring harness that I found at a local Pick'n Pull
https://www.youtube.com/watch?v=88jkW4mC8oY
Old 05-01-2021, 09:13 AM   #9
KyFarm
KyFarm's Avatar
I looked and nobody seemed to have the hose in-stock locally so I immediately ordered that sucker on-line, very interested to get that crossed off the list, Thank-you again. It should work, your radiator looks very similar to mine.
I also used a dual fan controller but went with a dakota digital, probably cost me more than yours did. It did, however, come with excellent wiring diagrams and the two relays needed. Said I could use the temp sender if it was from Classic Instruments, which mine is. So we'll see.
Getting ever closer to start-up.......
