03-02-2016, 05:24 PM | #1 |
Tilt steering column
Will a tilt steering column from a '73 C10 be a direct bolt in for a '72? thanks
03-02-2016, 07:55 PM | #2 |
Re: Tilt steering column
No, it was a generational change then the 73 is the first model year of what is called the squares and it lasted in the pickup until 1987. the steering column is a larger diameter and has the key and ignition switch in the column and of course the 72's did not. Jim
03-02-2016, 08:38 PM | #3 |
thank you...
