03-23-2014, 12:55 PM | #1 |
Carpe manana
Need help with measurements please, single vs. double wall side window dimensions...
I believe the side window openings for a single vs. double wall top differ in size. If anyone has a single and/or double wall top with the windows out, could you post the dimensions of the aperture: front to back and top to bottom?
I've tracked down a set of slider windows and suspect one of the two top designs needs to have the opening widened to accommodate the windows. A difference may also in part explain why there are separate gaskets for the two tops. Thanks!!
03-23-2014, 07:21 PM | #2 |
Re: Need help with measurements please, single vs. double wall side window dimensions
thought they were the same,i have both here can measure and post tomorrow
03-23-2014, 08:27 PM | #3 |
Geez, i thought they were the same size, and the differance was in the thickness of the fibreglas top
Guess well have to wait till tomorrow
03-23-2014, 11:45 PM | #4 |
Carpe manana
Thanks guys...I'm really curious.
03-24-2014, 08:42 AM | #5 |
I think this has been debated before, not sure if there was a clear answer. My top has one gasket and window from a double wall and one gasket and window from a single wall, I cant tell the difference.
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
03-24-2014, 09:36 AM | #6 |
2WD Jimmy
No difference in size or thickness. Just had all mine replaced with custom cut glass. Used the old double wall glass for templates. Fits perfect in the single wall top.
03-24-2014, 09:59 AM | #7 |
Carpe manana
The glass is the same but I suspect the openings have slight differences (3/8"?) in size. GM did make separate gaskets and this set of installation instructions for a NOS slider window I found indicates that one of the two styles needs the opening enlarged, which suggests that the sizes do differ. As shown, one gasket style is offset from the other relative to the wall. I'd like to know if I need to plan for enlarging the opening to do a slider install beforehand (in my case into a single wall top). The diagram illustrates the differing gasket configurations and glass relation with regard to the wall of the top(s).
03-26-2014, 08:00 AM | #8 |
Carpe manana
bump
03-26-2014, 04:29 PM | #9 | |
04-03-2014, 03:08 PM | #10 | |
Carpe manana
Bump for the measurements.....anyone?
04-03-2014, 04:01 PM | #11 |
Parts manual is showing four glass part numbers (two tinted and two clear) along with two different gaskets.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-03-2014, 11:59 PM | #12 |
Carpe manana
Huh....four glass numbers, two tops, clear vs. tinted. That implies differences in the glass for 1x vs. 2x tops.
04-14-2018, 10:55 PM | #13 |
Carpe manana
Reference pic shows single wall glass (thin) adjacent to double wall glass (thicker).
