Old 10-04-2018, 10:06 AM   #1
Ehud
Sway bar 1995 2 door Yukon
I currently have a 1995 2 door Yukon with a 2” torsion lift on the front and 2” blocks on the rear. I would like to minimize the sway as much as possible. It has a factory sway bar but I am looking for improvement. I primarily use this truck for over the road driving not for off road use. Does anyone have any suggestions for an upgrade?
Ehud is offline   Reply With Quote
Old 10-04-2018, 11:17 AM   #2
82C10step
Re: Sway bar 1995 2 door Yukon
The factory one is hollow. The Dorman replacement is solid. It made a big difference on my K1500. The part number is 927-101
82C10step is offline   Reply With Quote
Old 10-04-2018, 11:21 PM   #3
Ehud
Thank you for the feed back. It looks like belltech makes a front and rear kit but it sure if it’s worth the extra money. So the Dorman would be the factory replacement?
Old 10-05-2018, 12:10 AM   #4
82C10step
Yes the Dorman is factory replacement. When you feel the weight difference between the two it's funny. There isn't much to the OEM one.
