11-16-2017, 01:19 PM | #1 |
Mystery wiring harness
Wondering if any of you guys know what this harness goes to? It looks original to the truck but I can't find anything that it fits. Truck is a 72 custom 10 without air and a 307 v8 and 350 turbo transmission. The 2nd pic shows it coming into the cab and plugs into a relay. The 3rd pic shows the plugins.
11-16-2017, 01:51 PM | #2 |
Re: Mystery wiring harness
Looks like A/C connections
11-16-2017, 01:55 PM | #3 | |
Msgt USAF Ret
there is plenty of info on the forums about it, also google has lots of information. Most of the owners of our trucks have ripped it out since the engines run better without it. Some of the relays were mounted on the engine side firewall. You don't have AC but the AC relay was mounted in the airbox if I recall correctly. That would be the only other stock installed harness.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-16-2017, 05:18 PM | #4 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
VetteVet is correct (not that he needs me to back him up) "just sayin"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
11-16-2017, 06:46 PM | #5 | ||
"I ain't nobody, dork."
I have a 1972 GMC that had the "Spark Knock" wiring as well. I removed it all without any problems.
Gary
11-16-2017, 07:03 PM | #6 |
That wiring harness is a transmission control spark harness. It plugs into the TCS vacuum solenoid.
I hope this helps. ....the green wire goes to the temp sensor under the exhaust manifold on the drivers side I believe. Last edited by Grandpas 72; 11-16-2017 at 07:40 PM. Reason: Added content |
11-17-2017, 12:52 AM | #7 | |
Interesting you should mention the green wire. What I found was a dark green wire that had been cut, and to-date I haven't been able to ID it. At any rate, I give up, what's a temp. sensor under an exhaust manifold? My truck also had a dark green wire that ran to the temp. sensor that fits into the head. But the wire came off the driver's side of the firewall block.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
11-17-2017, 03:32 AM | #8 |
Guys I really appreciate the responses. The original engine is gone along with the emissions equipment. I wanted to remove this harness if it didn't have a reason to stay but I didn't want to remove something I may need.. I will go ahead and remove it and put a plug in that hole.
