09-29-2017, 03:18 PM | #1 |
Chevy Performance Musclecar Oil Pan Kit 19212593 Question
I wanted to know if anyone is using this oil pan on an LS, specifically, LS3, how much lower than the crossmember this pan hangs if at all?
68 |
09-29-2017, 10:02 PM | #2 |
Re: Chevy Performance Musclecar Oil Pan Kit 19212593 Question
I can tell you that pan is only about .75" shorter than the truck pan is so it will hang below the crossmember a little. Unless your truck is slammed you should be ok but if you want it above the crossmember, you should look at the F body pan or the CTS-V pan. Check out the LS swap section, more info there.
