Old 12-13-2017, 11:14 PM   #1
weim55
Do 16" drop center (non split rim) 8 hole clip hub cap wheels exist?
Any of you have, seen or heard of these?
thanks,
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 12-14-2017, 09:18 AM   #2
buggy5872
buggy5872's Avatar
Re: Do 16" drop center (non split rim) 8 hole clip hub cap wheels exist?
I believe the only way you will find any are from someone cutting the centers out of the wheel and putting a new hoop on them. I made a set of 16" with my 6 bolt centers and f250 outer wheel hoops. Not that hard if you can weld and have access to a lathe to true them and weld them on.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 12-14-2017, 09:49 PM   #3
whitedog76
You’ll have to add the clips to pretty much anything you find.
Look at 03 and newer Ford E250/E350. They have steel wheels without the bumps on the center ring.
whitedog76 is offline   Reply With Quote
Old 12-14-2017, 11:30 PM   #4
weim55
Good idea, I'll take one of my original 3/4 ton hub caps and see if this is doable.
Thanks,
Old 12-15-2017, 10:15 AM   #5
paulspickupparts
The only original Chevrolet original that I know of are 17.5 and then the super hard to find 19.5 . Both are also tubelsess which is nice. Both came with the hubcap cliips. There are wheel companies that can take the center from a 8 lug split rim with clips and pit a tubeless outer onto that center.
paulspickupparts is offline   Reply With Quote
